More HP
Old May 26, 2013 | 08:45 PM
Canadaboy's Avatar
Canadaboy
Default More HP
As I am new to this Corvette thing I was wondering what is the easiest and the best way that isn't going to brake the bank to get 30-50 Hp out of my stock Ls1 engine?
Old May 26, 2013 | 09:18 PM
oh1vette's Avatar
oh1vette
CAI, LT Headers, and tune...
Old May 26, 2013 | 09:50 PM
bikeriderga's Avatar
bikeriderga
CAI, Underdrive Pulley, Tune, 160 thermostat, Ported Trottle Body, HP wires, and custom tune, can get you about 30-35 more HP. That is at the crank.
If you want up to 70 more HP, add headers to the mix and iridium plugs. Again at the crank. This should get you right at 400 RWHP.
Old May 26, 2013 | 10:10 PM
Canadaboy's Avatar
Canadaboy
Cai?
Old May 26, 2013 | 10:14 PM
alxltd1's Avatar
alxltd1
St. Jude Donor '10-'12-'13-'14-'15-'16-'17
Cai?
CAI Cold Air Intake (not manifold) IE Vararam. Do a search and you will find a number of options.
Old May 26, 2013 | 10:38 PM
Canadaboy's Avatar
Canadaboy
ok thanks and what is meant by a custom tune?
Old May 26, 2013 | 11:03 PM
alxltd1's Avatar
alxltd1
Corvettes utilize a computer controlled engine mnagement system. A customized tune will maximize the computer controls to get the most horsepower from the engine. Again a search will provide you with a wealth of information from the basics on how it works and what a customized or performance tune will do.
Old May 26, 2013 | 11:08 PM
lionelhutz's Avatar
lionelhutz
Headers, cold air intake, tuning and LS6 manifold if you doesn't already have one can move you from about 295-300rwhp up to around 330-340rwhp.
Originally Posted by bikeriderga
...This should get you right at 400 RWHP.
You're using a ridiculously optimistic dyno to get a LS1 anywhere close to 400rwhp with some bolt-ons.
Old May 27, 2013 | 12:41 AM
baxsom's Avatar
baxsom
it took all those bolt ons plus new heads and a cam to get me at 440 rwhp. those last 40 were expensive i guess. with LS6 intake, headers, and a mail in tune i was right at 330.
Old May 27, 2013 | 12:43 AM
baxsom's Avatar
baxsom
aren't the oem plugs iridium?
Old May 27, 2013 | 01:12 AM
StingrayRebel's Avatar
StingrayRebel
throw some ls6 heads in the mix and it would be mighty close
Old May 27, 2013 | 01:48 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Well,,,, Its widely known and well understood that SPARK PLUGS & PLUG WIRES (NO matter who makes them or how much they cost) will NOT increase HP or Tq on our C5's or C6's.
If you replace damaged, worn or defective wires and plugs, you will gain back any LOST performance that was caused by the bad plugs and wires.
In fact,, ported 160 deg stats don't directly ADD power either. It just helps keep the engine cooler so timing isn't reduced when it very hot
Real increases can be seen by adding, LT headers, Cold Air Intakes, CAM and ported higher compression heads (on NA applications)
Once you start increasing POWER, you will find out that you have to improve other parts; Bigger injectors, better valve springs push rods and rockers, ect Oh,, then theres the TUNE.. It has to be done..
Then some find that their clutch goes south or their A4 cant handle the power or the rear end pops an output shaft.
Its a slippery slope and a sickness!!
Old May 27, 2013 | 03:43 PM
cdnguyred88's Avatar
cdnguyred88
and no cure.....
Old May 27, 2013 | 04:28 PM
YELLO C5's Avatar
YELLO C5
Speed costs. How fast do you want to spend?
To More HP
