Starter Brand Advice
Old May 27, 2013 | 05:34 PM
SVTBAIT's Avatar
SVTBAIT
2015 C5 of Year Finalist
Default Starter Brand Advice
I've come to the conclusion that my car needs a new starter. I'd like to replace it with a starter with the reinforced side. I'm just not sure what brand to go with - I'd like to do this in a cost-effective way. Does anyone have experience on a cost-effective starter?
Any brand to go with or stay away from?
Cheers,
Old May 27, 2013 | 05:47 PM
bumble-z's Avatar
bumble-z
What's wrong with going with the same starter as in the picture you posted up?
Old May 27, 2013 | 05:51 PM
SVTBAIT's Avatar
SVTBAIT
I believe it's a GM one. If memory serves me correctly it's around $300 and I've seen some going for half that price.
Old May 27, 2013 | 05:53 PM
bumble-z's Avatar
bumble-z
make sure it has the reinforced bracket & longer bolt.
Old May 27, 2013 | 06:25 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
Its not the lack of a long bolt or reinforcement that cause failure, its the heat from the exhaust manifold that causes distortion of the solenoid contact. the best advice would be to buy a starter with a lifetime guarantee. these starter failures occur after many years, 4 or 5 or 6 and as long as ten years. Headers increase the chances of failure because of their design.
A rebuilt starter with a lifetime guarantee is a better choice than a New starter with a one year guarantee.
Old May 27, 2013 | 07:31 PM
bumble-z's Avatar
bumble-z
ET,
I wasn't referring to the extreme heat near the starter.....that's a given.
I was referring to a much uglier scenario ...& the (OP) original poster is about to change his starter.
http://ls1tech.com/forums/generation...r-bolts-2.html
http://ls1tech.com/forums/general-ma...ock-broke.html
Old May 27, 2013 | 07:48 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The starter that you pictured exist.. It is MUCH more ROBUST than the C5 OEM Starter. I have the bulletin at work and I will try to locate it. I believe its an iron block LS Starter but fits our C5 with out any issues.
All you need to install it is to purchase a new LONG Starter bolt. Look at reman from Advance or AZ. Very cost effective.
Bill
Old May 27, 2013 | 08:40 PM
Maxx_Z06's Avatar
Maxx_Z06
C5 COTM Coordinator
I replaced my starter with a new (refurbished) AC Delco one. My solenoid was bad and the starter itself had wore out brushes. I went ahead and also purchased a starter heat shield since i'm running LT headers. Everything was ordered from Amazon for a great price with no core exchange required. She starts up sooo easy now. Hope it helps.
Old May 27, 2013 | 09:41 PM
YELLO C5's Avatar
YELLO C5
I had the cracked starter motor and engine boss. Found my replacement that used the longer bolt on ebay. I think it was $70 and was working fine but only had it on a year before the motor died.
Old May 27, 2013 | 10:24 PM
Evil-Twin's Avatar
Evil-Twin
Oh IM not saying, a reinforced starter is a waste of money. IM saying that starter failure is usually due to heat distorting the solenoid Now if you could buy a reinforced starter with a lifetime guarantee, you would be in good shape. I am away that there are two failure modes, one, the cracked starter housing and two, the solenoid failure which happens much more frequently.
To Starter Brand Advice
