School me on the PCV system...
I'm wrapping up my FAST 92/90 install on my 2002 Z06. Last piece of the puzzle is re-routing my PCV set-up as the LS2 TB doesn't have a port for the PCV. I also have a catch can installed.
I was going to route my set-up just like Mark (Toque), but I'd like to try and avoid any potential vacuum leaks. Here's his set-up:
My concern is the hose/end assembly going into the air coupler. He doesn't seem to be having any issues but it concerns me since that hole is nearly an inch wide and getting a good seal there is very important.
So I did some research and found this neat little fitting:
http://www.atpturbo.com/mm5/merchant...egory_Code=BCS
My concern with that fitting though is that it might be too small to allow the PCV system to breathe and allow good airflow. It says to punch a 5/16" (8mm) hole into the air coupler if that helps...
Can anyone help with input on that matter?
Another option I've seen is some people have simply installed a breather filter on the passenger side valve cover. Something like this:
http://www.autozone.com/autozone/acc...er=480746_0_0_
I'm not sure if that exact one would work, or what pros/cons to this set-up vs. into the air coupler there are - any insight would be greatly appreciated. If anyone has a specific part # for a breather filter that would work, I'm all ears...
I have a tune scheduled on June 10th and this is the last piece of the install I absolutely need to wrap up.
Thanks for all the help!
http://forums.corvetteforum.com/c5-t...pcv-valve.html
What I'm trying to figure out is the best method for the passenger side valley cover since the LS2 TB doesn't have the port that the LS6 TB does.
I'm considering either using a method similar to Toque where I obtain vacuum from the coupler to the TB or possibly Y'ing into my catch can and using the intake manifold as my single source of vacuum.
Another issue I thought of though - and this would apply to just about everyone and not just me. When you install a catch can, you remove the hose that has the inline PCV valve in it - but all the installs I've seen don't re-use the PCV valve.
See below - that's the OEM set-up with the inline PCV valve.
.gif)
Here's Mark's, and just about everyone else's install:
Why don't we re-use the PCV valve? That doesn't seem right. I have to be missing something though as literally everyone else runs their catch can set-up this way.
Any help would be great here, otherwise I'll talk to my tuner and see if he can offer any advice...
The valley cover I have installed is the later self metering and I run that through the catch can into the intake manifold. Fresh air is provided similar to your picture from Toque. I have never had an issue with it.
I don't like the breather idea because the air coming in is not metered by the MAF.
Found this little diagram which I'll re-route for my catch can:
So, that's one issue out of the way...
As for the rest of the PCV system, I may try to Y it, or I may try the ATP fitting when it arrives. I forwarded this all to my tuner to get his thoughts on the best way to run it as well. I'll be sure to report back.
Appreciate the help everyone. Always open to more insight but I think I have a better grasp on all this now...
.gif)
I see you found the setup I was saying to use to retain the PCV valve between the catch-can and the intake manifold.
Another option is to find a small 90* fitting that matches the hose from the valve cover and a grommet the 90* fitting fits snugly into. Put the right size hole for the grommet into the air bridge and then plug the 90* fitting into the grommet. Basically, duplicate that fitting in the Vararam that feeds the AIR pump.
Thanks for the help everyone! I'm almost there
I installed the pcv valve into my catch can last night...
Anything look out of place here? Besides what I stated above...
Don't mind the 'seal' I made with the RTV on the power duct either...all temporary haha.
A HUGE thanks to Mark for his write-up! I would've been lost without it at some parts of this install.
I still have to shave the FRCs to clear the new mani too.
Got a tune scheduled on Monday so things are coming along!
Oh, and I need to pick up my sway bars from the powdercoating shop too...
Toque
