need some help please!!!
Old May 29, 2013 | 11:17 PM
momo20's Avatar
momo20
Default need some help please!!!
so I have a 3rd to 4th gear grind in my car...it does have fresh fluid amsoil torque drive, but it still grinding, I have followed the how to on adjusting the shifter, but it still does it. I am just at a crossroad on if I should pull my transmission or not..can the 3rd and 4th gear synchronizers be replaced by them selves or is it deeper then that?
so with that said I am thinking its time to pull the transmission and have it fixed. I am pretty confident that I can do this my self, just a bit nervous is all..i have several how to's saved, but any other advise I can get on what all I should do while the drivetrain is removed from the car...its a 2003 Z06 44k miles.
thanks for your time!
Old May 30, 2013 | 12:08 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You either have a blocker ring issue OR a clutch fork pad issue. Most likely a blocker ring/synchro wear issue.
Many people have repaired their T-56 them selves BUT,, it does take some special pullers and bearing pressed, dial indicators and set up procedures.
Many forum post on that very same topic. If you need professional help, I can recommend one of the best going.
Bill
Old May 30, 2013 | 01:10 AM
momo20's Avatar
momo20
Bill
that is what I was afraid of. whom would you recommend if you don't mind me asking?
Old May 30, 2013 | 01:23 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I strongly recommend Forum Supporter Rick Kim
RKT56
http://rkt56.com
Phone number: 301-257-0930
205 Bucheimer Road, #C
Frederick, MD 21701
Give him a call and discuss issue and your options
Bill Curlee
Old May 30, 2013 | 08:34 PM
momo20's Avatar
momo20
talk to rik kim and he seems to think its my blocker rings I think he what he referred to them as causing the grinding issues..and that makes sense and seems like more of what it could be causing my issues...
I talked to a few other people today and they all seem to think its my clutch master cylinder that is going out and needs to be replaced with a adjustable one, which make ok sense to me, but my fluid is clean as I do the ranger method once a month, and I have only had the clutch pedal to the floor once meaning I had to pick it back up with my tip of my foot...so any more ideals?
Old May 30, 2013 | 08:42 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Hmmmmmm,,, Put the car in FIRST GEAR on flat level ground. Release the brake and rev the engine up to around 5000 RPMs.
If you have a CLUTCH RELEASE issue, the car will creep or move forward.
If you have a clutch issue, you will have other issues shifting UP and DOWN thru the gears.
Its always a good Idea to keep the clutch fluid clean and fresh but,,,,,,,,,, thats not going to help your issue.
BC
Old May 30, 2013 | 08:47 PM
momo20's Avatar
momo20
ok I will go try that and report back..thanks bill for taking time to respond back to this..!!
To need some help please!!!
