door sag on 1997
Old May 30, 2013 | 10:06 PM
kennedy759's Avatar
kennedy759
Default door sag on 1997
it drops about 1/4 in, how do you fix it? its in the hinge pin
Old May 31, 2013 | 12:36 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Order FOUR new hinges. They DO wear and a new set will make the car feel new again.
Check here
www.gmpartshouse.com
Bill
Old May 31, 2013 | 10:50 AM
kennedy759's Avatar
kennedy759
how do you install a new hinge and keep the door aliened?
Old May 31, 2013 | 11:07 AM
GySgt1811's Avatar
GySgt1811
Old May 31, 2013 | 10:10 PM
kennedy759's Avatar
kennedy759
??, I see your in corydon, I am in New Salisbury
Old Jun 6, 2013 | 10:27 PM
kennedy759's Avatar
kennedy759
anyone with a link to instructions on hinge replacement?
Old Jun 6, 2013 | 10:39 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I have the procedure but the pictures will NOT come thru.
Document ID# 98430
1997 Chevrolet/Geo Corvette
Door Hinges - Side Door
Removal Procedure
Mark the location of the hinge.
Support the door.
Remove the bolts securing the hinge to the hinge pillar.
Remove the bolts securing the hinge to the door.
Remove the door hinge.
Installation Procedure
Install the hinge and attaching bolts to the door.
Install the hinge and attaching bolts to the hinge pillar Tighten
Tighten the hinge attaching bolts to 30 N·m 22 lb ft.
Notice
Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
Remove the door support and check the alignment of the door.
Document ID# 98430
Old Jun 7, 2013 | 09:24 AM
kennedy759's Avatar
kennedy759
can you adjust the old hinge by loosing the bolts, lifting the door up and tightening the bolts, or is there no adjustment? If I do replace the hinge, can I just replace the top one since it seems it would be the one with the most wear?
Old Jun 7, 2013 | 02:24 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I’ve been to the GM Plant in Bowling Green KY numerous times. One of my favorite parts of the line is where they put on the doors. The front clip isn’t on yet so, this big arm picks up the door and one person swings it over to the car. The fixture has spacers that fit into the opening to properly center it. Then the bolts on both hinges are tightened. If you remove the fender, alignment and bolt tightening is easy!
Old Jun 8, 2013 | 10:37 PM
kennedy759's Avatar
kennedy759
ok, stupid question, how do you remove fender, I see the screws under the hood, and under the fender at the door, but what screws at the front of fender and wheel well?
To door sag on 1997
