Radiator Pressure Relief
Old Jun 1, 2013 | 12:27 AM
flynhi's Avatar
flynhi
Default Radiator Pressure Relief
My 99 has bee losing coolant. I have no drips in the garage so I must be leaving it on the road.
Can someone tell me where the pressure relief/overflow vent is. Perhaps that's the culprit.
Old Jun 1, 2013 | 07:21 AM
vettenuts's Avatar
vettenuts
One other place may be the o-rings on the steam tubes. Can you smell it? I had a coolant loss issue on an old Chrysler and didn't find it until the headlight went. I drove home from the store with the new headlight and with the hood open I could smell it and finally tracked it down.
Old Jun 1, 2013 | 07:40 AM
xdmikey's Avatar
xdmikey
Flynhi, what's your mileage?
Just trying to gain insight into my car.
Old Jun 1, 2013 | 08:14 AM
3boystoys's Avatar
3boystoys
Or BURNING it.
Old Jun 1, 2013 | 08:33 AM
flynhi's Avatar
flynhi
Vehicle has about 80k miles. Lingenfelter LS 3 has about 55k miles. Not sure if water pump was replaced when engine work was done or not.
Old Jun 1, 2013 | 08:36 AM
flynhi's Avatar
flynhi
Originally Posted by 3boystoys
Or BURNING it.
If I was burning coolant, seems like I would see a different exhaust color or experience missing. Other than occasional rough idle, which I attribute to ethanol, the engine runs very well.
Old Jun 1, 2013 | 10:28 AM
flynhi's Avatar
flynhi
If my problem is a failing water pump and shop rates are about $90/hr, about how much should a replacement water pump cast (parts and labor)?
Thanks el mucho.
Old Jun 1, 2013 | 10:43 AM
dblerman's Avatar
dblerman
Thanks el mucho.
Parts and labor, shouldn't be more than $300-350
But seriously, do the work yourself, it's literally 6 bolts.
Old Jun 1, 2013 | 11:22 AM
dadaroo's Avatar
dadaroo
I suggest you drive it till it is up to temperature, pull over and look to see if you are getting a puddle. I think it is most likely the water pump. But the leak location should be evident if it is external.
Old Jun 1, 2013 | 01:02 PM
flynhi's Avatar
flynhi
Originally Posted by 8VETTE7
If you examine the area around the water pump you should be able to see coolant stains to verify that is the issue. While leaking coolant will evaporate on a hot engine while driving, it also leaves stains that indicate what is happening. You should be able to see this from the top but might be a bit easier if the front of the car were in the air so you could look from the bottom.
Quoted price is about right depending upon your area and dealer vs independant garage. You will need a new pump, thermostat cover, gasket for the cover and thermostat. The older OEM style pump is no longer available and the replacement does NOT come with the cover for the thermostat, cover gasket or the new thermostat. Old cover does NOT work with the new pump.
You should be able to buy the parts for less than $150 and save significant $$$ if you are mechanically inclined.
Thanks to all for comments.
With the mileage on the engine (65k or so), should I preemptively replace alternator, PS pump, seep belt, tension roller, etc?
It's my DD and I intend to keep it for several years.
Thanks again.
Old Jun 1, 2013 | 01:24 PM
dblerman's Avatar
dblerman
Thanks again.
I wouldn't replace the alternator or power steering pump unless there was a reason. 65K miles is nothing and they will likely be working fine after 150+K miles.
As for the belts, if they're old I'd replace them since they're cheap enough and while the belt is off you can give the tensioner and idler pulleys a spin and check the condition of the bearings.
Edit: 8VETTE7 got it in before me by just a few seconds >_< haha
Old Jun 1, 2013 | 01:27 PM
3boystoys's Avatar
3boystoys
Never seen a PS pump ever fail, alternator is easy to change anytime.
Old Jun 1, 2013 | 11:55 PM
flynhi's Avatar
flynhi
What if the CF wisdom on temp rating of thermostat? 165, 180, 195 or ?
Old Jun 2, 2013 | 08:01 AM
flynhi's Avatar
flynhi
You said your C5 is a DD. I would use the factory thermostat which I thought was about 187. Running a colder thermostat like a 160 or 170 serves no purpose unless you have the turn on/off temps of the cooling fans reprogrammed down to a lower temp. Plus if you drive the car in cold weather you won't get the engine temp high enough to provide you heat or to burn off condensation that may form in the oil with a 160.
Thanks for your comment. Prior to this recent coolant situation, typical digital temp was pretty consistent at 192. So, I'll replace with the factory t-stat.
To Radiator Pressure Relief
