Help what is this, How to fix?
Old Jun 3, 2013 | 12:51 PM
bradleyls103's Avatar
bradleyls103
Default Help what is this, How to fix?
Just noticed this is cracked. What is it? How hard is it to fix? What is part number and cost? Any advice would be helpful.
Thanks.
Old Jun 3, 2013 | 12:52 PM
JetMechZ16's Avatar
JetMechZ16
Can't see your pics.
Old Jun 3, 2013 | 01:00 PM
VinnyT's Avatar
VinnyT
PCV system. I had to replace mine awhile back.
Old Jun 3, 2013 | 01:03 PM
Zorlac's Avatar
Zorlac
I think its a part of your pcv plumbing. Probably inexpensive at NAPA and simple to replace. A vacuum leak causes headaches.
Old Jun 3, 2013 | 01:09 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
PCV connection to the intake manifold.
YES, it will get worse and YES it will cause a bad vacuum leak. You have to get the entire thing from the dealer but you can cobble in a piece of vacuum line.
BC
Old Jun 3, 2013 | 01:14 PM
VinnyT's Avatar
VinnyT
I had to replace the whole assembly. All the hoses/elbows were disinegrating/collapsing.
Old Jun 3, 2013 | 02:02 PM
bradleyls103
The part pulls right out and is about a 1.5" rubber. Not sure I need a full assembly?Does anyone have more info or a part number?
Old Jun 3, 2013 | 04:47 PM
BigGun's Avatar
BigGun
See Bill's post, #5. Vacuum hose works fine you don't need that lip like is on the original.
To Help what is this, How to fix?
