advise on a clutch
Old Jun 4, 2013 | 10:20 PM
momo20's Avatar
momo20
Default advise on a clutch
while my transmission is out being built..i figured with 44k on the clock might away install all new clutch components, I am going to install the remote bleed as well..
as far as my mods go I have vararam intake with power duct, lg streets long tube headers, corsa indy exhaust, tune from ecs
I am thinking about just putting in a new ls-6 clutch kit as I don't for see my self going over the 450 hp atm..also who has the best deals on the clutchs that come in kits..
thanks
Ryan
Old Jun 4, 2013 | 10:58 PM
racebum's Avatar
racebum
sticky clutch is just a design flaw with oem
monster stage 1 or ram power grip won't have that fault
from what i gather the self adjusting pressure plate is what causes most all of our problems
possible the 04 master cylinder and or the 1/8th drill mod could cure it.
kind of curious myself if there is an actual fix for the weird feeling OE clutch
if there is an ls7 clutch and fidanza flywheel would be a decent street setup
Old Jun 4, 2013 | 11:07 PM
momo20's Avatar
momo20
interesting , what do you think of the tick adjustable master cylinder?
Old Jun 4, 2013 | 11:08 PM
David426's Avatar
David426
LS-7 clutch.. Call Gene Culley. He will hook you up with a kit that includes a new flywheel that will work on your tranny! Best bang for the buck,, hands down!
Old Jun 4, 2013 | 11:12 PM
momo20's Avatar
momo20
you think so? that is not overkill for what I am going for?
Old Jun 4, 2013 | 11:17 PM
racebum's Avatar
racebum
tick master should help, it flows more fluid but also increases pedal effort
the ls7 clutch may work if you use a lighter flywheel. the oem ls7 flywheel is HEAVY. adds 10lbs onto the clutch package over an ls6 stock setup.
have noticed a lot of sellers using the 19lb ram flywheel with the ls7 clutch to keep the weight down around factory
biggest question i would have is will the ls7 clutch have that same sticky pedal as the ls6 from the self adjusting plate
ls7 clutch may seem like overkill but it's actually cheaper than an ls6
monster stage 1 is the other popular one but i'm not sure what you would do for clutch adjustment with an oe master
Old Jun 4, 2013 | 11:36 PM
David426's Avatar
David426
Not over kill at all.. A Tick Master Cylinder is a great idea and highly recommended, as racebum stated.. The weight issue is no big deal to me.. Go on a diet if it is a big deal to you... LOL! Go out and start pricing all this stuff yourself.. LS-7 clutch, Tick Master Cylinder and LS-7 flywheel is the way to go for you in my opinion, for what you will do with your mods.. Lots of other options out there for you too! And yes, they will cost you too..
Old Jun 4, 2013 | 11:51 PM
racebum's Avatar
racebum
it's not the 10lbs, it's where the 10lbs is
heavy flywheels like to keep going once you spin them. absolutely not what you want if you autocross, hammer it and let off or know how to heel/toe shift
they are okay for around town driving since they typically start off easier and can be alight for drag racing since, like i said, once they spin, they keep going.
revs go up slower and come down slower
i think the ls6 flywheel is a bit too heavy. couldn't even imagine what an ls7 would feel like, yikes
Old Jun 5, 2013 | 01:07 AM
momo20's Avatar
momo20
valid point racebum, any ideal why the ls7 flywheels is so much heavier? then say the ls-6?
Old Jun 5, 2013 | 01:09 AM
racebum's Avatar
racebum
i don't actually know but the ls7 is a 427 with even more low end torque
the popular ls7 combo i've read about on the c5 is to use the ram 19lb flywheel.
vendors often sell the matched set in the high 500 range
Old Jun 5, 2013 | 01:12 AM
momo20's Avatar
momo20
that is not a bad deal then.. sorry for the stupid questions, but when you say matched set does that mean they come zero balanced or does one have to do that before they install it on the car?
Old Jun 5, 2013 | 01:28 AM
racebum's Avatar
racebum
that's actually a great question. i have no idea what degree of balancing goes into these. with race cars you can put a flywheel/clutch/plate on the spintron and gram balance it
not sure how close it is out of the box
by matched set i meant the correct flywheel for the ls7 clutch, you then use c5 hydraulics and are good to go
the ls7 clutch/plate with ram flywheel, 2004 master and slave is one thought i'm having
the strong plate clutches like monster do not self adjust which i would think means you need an adjustable master. having chatted with people the tick master increases pedal effort fairly substantial. no biggie for a race car but i drive in traffic. ram also has an adjustable master. i also have no idea what it does, if it's a modded stocker or if it's a big piston design like tick
so, i'm not sure what a guy does if he wants the oem master/slave but a clutch that won't suck to the floor or feel weird when driven hard.
ls7 clutch + the 04 master/slave would give you that factory feel and more holding power. i'm just not sure what it would feel like if i went drag racing or did a HPDE day
Old Jun 5, 2013 | 01:59 AM
Ohyoufan's Avatar
Ohyoufan
The ls7 clutch is heavier and in return your RPM's move a lot slower. The ls7 clutch also has a self adjusting pressure plate, the part that actually causes high RPM lockout and sticky/mushy clutch syndrome. A lot of people go with this clutch for the factory feel, but if you don't use the Tick master there shouldn't be much of a difference if you go with an aftermarket clutch that doesn't have a self adjusting pressure plate. (I myself opted for the Tick, a stiffer pedal doesn't bother me). While brand new the ls7 clutch doesn't have issues, eventually that self adjusting pressure plate will do the same thing any ls1/ls6 clutch does and gets mushy and sticks to the floor with age. At the very least I'd go for a Monster stage 1, I went with the stage 2 myself because it was only $50 more and held 100 more rwhp without any different pedal feel.
Old Jun 5, 2013 | 03:03 AM
racebum's Avatar
racebum
so what happens if you use a non adjusting plate with an oe master cylinder? seems like you would have no way to set engagement
monster stage 1 with an oe master seemed like the way to go for a daily driver clutch with the slip of organic material
i just was curious what a guy did for pedal adjustment. i know with the tick it's adjustable
but the oe isn't
Old Jun 5, 2013 | 01:50 PM
Ohyoufan's Avatar
Ohyoufan
but the oe isn't
You don't have adjustment, you just have to set it up right the first time and that's how its always going to be, of course with time you'll break the clutch in and the pedal will slowly rise, but where the pedal sits is where it's going to be. I know that Toque (Mark) has a Monster Stage 2 clutch with a OE master cylinder, you might want to get in contact with him to see how it feels, I hear it feels not much stiffer than stock at all.
To advise on a clutch
