Rebuilding Differential ???
Old May 30, 2013 | 07:25 PM
96juicedgt's Avatar
96juicedgt
Default Rebuilding Differential ???
Got the trans and differential apart in my 2001 Z06 right now. I am upgrading to a 30 spline mainshaft. My question is what are my options as far as the differential goes? I see Motive has gear sets that are 30 spline units (V885390L). Will those work with the upgraded mainshaft? Or will I have to have mine re-splined?
Old May 31, 2013 | 09:50 PM
96juicedgt's Avatar
96juicedgt
Anyone?
Old Jun 3, 2013 | 06:57 AM
96juicedgt's Avatar
96juicedgt
This is the gear set I was looking at. Shows to have a spline count of 30 so I was hoping I could just run this instead of having my stock one re-splined.
http://www.summitracing.com/parts/mg...390l/overview/
Old Jun 3, 2013 | 12:03 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Looks like the correct stuff.. You do know that who ever replaces the gear/pinion needs to have the correct Kent Moore set up tool to get the pinion and output shaft bearings properly set up.
Here are a couple of post that you may be interested in:
- C5, ragtopws6 , Upgrading your C5 rear with C6 Z06 guts, : http://forums.corvetteforum.com/c5-g...-z06-guts.html
- C5, Its_Go_Time, Output Shaft Install - Left and Right: http://forums.corvetteforum.com/c5-t...post1573407966
- C5 Differential Seal replacement: http://forums.corvetteforum.com/c5-g...on-photos.html
- C5 ragtopws6, T-56 Build (whats in my tranny?) : http://forums.corvetteforum.com/nort...-smoother.html
Hope this helps..
BC
Old Jun 3, 2013 | 03:08 PM
voda1's Avatar
voda1
Seems like wrong info in add. C5's used 27 spline shaft. Have pic of Motive catalog page and no spline count is given. But it excludes c6-z06 use which had the 30 spline. More info here:http://forums.corvetteforum.com/1581542686-post1.html
Old Jun 4, 2013 | 07:21 AM
96juicedgt's Avatar
96juicedgt
Thanks for the info guys! I really appreciate it.
Old Jun 4, 2013 | 12:21 PM
DIXZ's Avatar
DIXZ
I have install 2 sets of V885390L and 2 sets of V885410L. All were direct replacements for C5 pinions. 27 spline.
I believe Summit's information to be incorrect.
Old Jun 5, 2013 | 07:27 AM
96juicedgt's Avatar
96juicedgt
Well looks like I will need to respline my stock unit. Where is the best place to have this done?
Old Jun 5, 2013 | 10:44 AM
voda1's Avatar
voda1
Forum vendors: RPM Transmissions or RKT56
Old Jun 5, 2013 | 02:08 PM
Rick@RKT Performance's Avatar
Supporting Vendor
St. Jude Donor '08-'09-'10-'11-'12, '14-'15-'16-'17-'18
Give us a call, we can have it done for you.
__________________
To Rebuilding Differential ???
