Dielectric silicone
Old Jun 5, 2013 | 05:02 PM
19vette91's Avatar
19vette91
Default Dielectric silicone
Can you use dielectric silicone compound on weatherstrip moldings?
Old Jun 5, 2013 | 05:48 PM
dadvan99's Avatar
dadvan99
Cruise-In VII Veteran
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
Oldtimer
My '99's owner's manual recommends using Dielectric Silicone Grease (GM Part No. 12345579 or equivalent).
Old Jun 6, 2013 | 08:15 AM
dcandel's Avatar
dcandel
Oldtimer
It works great to keep moldings soft so they seal properly, however it does not soak in to the rubber and leaves a permanent greasy film so be careful not to brush up against any rubber with your good clothes on.
Old Jun 6, 2013 | 12:16 PM
Ultimate ride's Avatar
Ultimate ride
I have for years used the liquid sillicone in the spray cans on the rubber. I soak a rag with it and rub it on the seals. It keeps them soft and is not greasy. I have never had a leak on my 1986 300ZX's t-tops or window seals or on any of my other cars. It keeps them soft and just like new.
Old Jun 6, 2013 | 10:23 PM
corvette77's Avatar
corvette77
Just remember that a little bit goes a long way with the grease.
Old Jun 7, 2013 | 06:56 AM
Cybermind's Avatar
Cybermind
Yes, it is the recommended weather stripping protection for most automakers. However, if you don't want the grease residue you can also use more conventional rubber protectants such as Meguiars, Mothers or Protectant 303. They work well but need to be applied more often. Personally, I prefer using dielectric grease.
To Dielectric silicone
