Rear lower than the front implications
So this is sad, but after driving my car for a year, I finally had it parked in the lot at work, dead level ground and in a spot I could get a good side view from 50 or so feet away.
I have the rear set lower than the front. Never could see that in my sloped driveway or small garage. Dumb, I know.
So just how does this affect the handling? The car is hardly slammed, just a bit lower than stock.
I believe I'll just raise the rear, instead of lower the front, but just wondering if this might be the source of the odd handling, and maybe even be messing up my drag strip launches.
Ron
Ron
Ron
When I first set up my car and we were doing testing on an autocross course, we found that forward bite (the ability to put down power on corner exit) was really effected by lowering the back. The lower we made it, the more wheelspin we got coming off of corners. We started with the back end lowered about a half an inch from stock and for every turn of the rear screws we lost lap time and the car had more wheelspin coming off the corners. I would go with about a half an inch from stock if I wanted to go to the strip and that should help your 60 ft time a lot.
i.e., 4.5" on the front jack point, 5" in the rear. Should get the same measurements side to side with you in the car, otherwise you have one side lowered more than the other.
I got 4 1/4" in front and 4 1/8" in the rear. I have the correct rake, just in the wrong direction.
I read another post (Thanks BumbleZ) that these numbers should be closer to 6". Hmm...
The car does have Z06 springs and some negative camber.
Ron
Ron
I like the lowered look, but in all honesty, the car is nervous with the present suspension settings on all but very smooth roads.
Ron
Can't just go by number of threads visible on the bolt as well - the first time I lowered the car I left equal number of threads showing between the adjustment bolts on both the front and back. I had unequal heights on both the framerails and fenders after this, so had to go back in and adjust.
You'd be surprised how much just getting everything square will help you, even in a straight line.
