Shift rod pin inside trans fell out HELP!
http://forums.corvetteforum.com/c5-t...ic-inside.html
Here is my post when the issue first happened:
http://forums.corvetteforum.com/c5-t...ssue-help.html
The local aamco shop will not work on my car so I had it towed to a better aamco in another town or them to start on the warranty claim. My question is, if all was fine before it was taken apart, and since aamco did the labor installing the pin etc shouldn't they be responsible for this happening so shortly after the rebuild? I am waiting on any further news from the shop, but just wanted people's opinions and wondering if this has happened to anyone else? Thanks
YES,, the pins should be a tight pressed fit and should never just fall out.
When I replaced my t-56 with a TRANSZILLA T-60/60 conversion, Chuck at Corvettes Of Westchester gave me a shift rod that had a small spot weld on each pin.
Good luck getting the shop to cover the repairs. If your are dead set on making them pay, you may have to take them to small claims court.
Bill
That was my thinking also but,,,,,,,,,,,,,, That’s water under the bridge. He now has to fight for resolution. You know that they are going to blame the fault on the part that failed and not on their work. Ask them where the RUBBER SLEVE IS and why didn’t they reinstall it!!!
1sickz51vette
If they do the repairs,, make SURE that you inspect the pin and insure that it is being retained properly. Like I mentioned previously, you could have the pin TIG tack welded so that it will not come out again.
GM does NOT sell any of the parts separately so, unless you purchase a complete rod,,,, fix what you got. You can get the roll pins if they are needed.
Bill
................Bill
Should be a rubber boot over the "U-joint" on each end that keeps dirt/debris out and serve as a backup to prevent pin from falling out. I do not think the rubber sleeves are a replacement item from GM. Check the pictures in this listing. I see them all the time.http://www.ebay.com/itm/1997-2004-C5.../180933525426?
Install oversize pin or knurl the one you have, or maybe even use a roll pin.
Just can't get enough or what?
Re read post #4.... in regards to that franchise shop.... it is the only thing that makes "Real Sense " in all this.
