rotor cutting
Old Jun 6, 2013 | 11:45 AM
Dave 127's Avatar
Dave 127
Default rotor cutting
Hi I havea stock C5 2004 can the rotors be cut? thanks
Old Jun 6, 2013 | 12:37 PM
corvettebob1's Avatar
corvettebob1
Sure they can be, as long as you don't go below the minimum thickness.
But really why? Personally I haven't machined rotors in 20 years they are a wear item just like your pads are.
There are a couple of venders on here that sell rotors and pad kits at very reasonable prices.
Old Jun 6, 2013 | 01:31 PM
Bill McCassey's Avatar
Bill McCassey
I have resurfaced both the front and rear rotors only to have them warp the first time I had to brake somewhat hard. Just replace them.
Old Jun 6, 2013 | 01:35 PM
racebum's Avatar
racebum
don't turn the rotors, either put pads on them as is if they are still flat on surface or buy new ones
Old Jun 6, 2013 | 06:11 PM
RonSSNova's Avatar
RonSSNova
I had my GM slotted and drilled rotors turned. Just .010" per side.
I was told that couldn't be done too...........
They work perfect and haven't warped. This was done last year.
Ron
Old Jun 6, 2013 | 06:21 PM
TastyBacon's Avatar
TastyBacon
I have done 14-hour endurance road races (not in a C5, but almost the same rotor/caliper setup) on cut rotors, and have never warped them. Your mileage may vary
To rotor cutting
