Assistance Please... ERR Codes, Beeps, Lights (Video + Codes)
Old Jun 6, 2013 | 08:54 PM
Zr-1Mike00's Avatar
Zr-1Mike00
Default Assistance Please... ERR Codes, Beeps, Lights (Video + Codes)
While it happens...
So I was driving back to work this evening from dinner when I attempted to raise the drivers window... it would not go up.
Then this happened: The gauges you see in the video went down to "0" and back up again.
Various display messages on the DIC came up: "Check Tire Pressure" "Service Vehicle Soon" "Service Active Handling" "Reduced Engine Power" "Shocks Inoperative" "Service Ride Control" "Service Traction System" "Service Tire Monitoring System" "Check Tire Pressure" and one you don't see in the Video "Max Speed 80 MPH"
I apologize for the shakey video and radio playing in the background (AND still driving) but I just grabbed my phone ASAP and took a brief video as it happened. Trying to be as detailed as possible. I will post in the Tech section as well. Thanks in advance!
The codes I pulled from the DIC: (Some repeat but I have never checked the codes before so there were quite a few)
10-PCM: 1 CODE
P 1626 H
28-TCS: 1 CODE
U 1301 H
38-RTD: 1 CODE
U 1016 H
40-BCM: 9 CODES
B 0432 H
B 0502 H C
B 0507 H C
B 2482 H C
B 2583 H
B 2592
U 1255 H
U 1016 H
58-SDM: 2 CODES
U 1301 H
U 1096 H
60-IPC: 8 CODES
U 1255 H
U 1016 H
U 1064 H
U 1040 H
U 1160 H
U 1056 H
U 1088 H
U 1176 H
80-RADIO: 3 CODES
U 1016 H
U 1096 H
U 1064 H
99-HVAC: 4 CODES
U 1064 H
U 1096 H
U 1160 H
U 1255 H
A0-LDCM: 7 CODES
B 2282 H
B 2284 H
B 2264 H
U 1255
U 1064
U 1016
U 1096
A1-RDCM: 6 CODES
B 2283
B 2285
U 1255
U 1016
U 1064
Old Jun 7, 2013 | 01:31 AM
Zr-1Mike00's Avatar
Zr-1Mike00
Originally Posted by 8VETTE7
Start by reading this thread. It seems to apply well to your symptoms:
http://forums.corvetteforum.com/c5-t...-there-is.html
Thank you very much!
Old Jun 7, 2013 | 04:27 AM
Zr-1Mike00's Avatar
Zr-1Mike00
The consistent U1255 (Serial Data Line malfunction) really points to the symptoms from the link above.
However, if the info from that link doesn't resolve the issue, there are some interesting codes there that could help also.
Have you recently been having problems with your battery or perhaps replaced it or disconnected it? Many of the codes for the RDCM and LDCM are typical of battery related issues. If you recently replaced the battery they would show up. But a weak or bad battery or loose or corroded battery connections including the one at the starter can also cause them. So I would also check out your battery.......
I will attempt to work through the information in the link you provided and see if that addresses the issue. Hopefully I will be able to get it home in a few hours from work and let it sit until I have time to tinker with it, most likely Saturday morning.
I haven't replaced or disconnected the battery in quite some time. (a few months I would say) I will also check my battery connections and have it tested.
The starter was replaced about 2,500 miles ago because I was having the infamous no start issue (Which Bill assisted me with) so I will check those connections as well.
Old Jun 7, 2013 | 06:47 AM
3boystoys's Avatar
3boystoys
Did the power windows stop working too?
Old Jun 7, 2013 | 06:02 PM
Zr-1Mike00's Avatar
Zr-1Mike00
Yes! I went to roll them up and nothing happened.... Then all hell broke loose! However it started up just fine last night and no lights or messages on the DIC.
Old Jun 8, 2013 | 08:40 PM
3boystoys's Avatar
3boystoys
Connections in the accordion tubes in the doors, common problem. Search on accordion.
Old Jun 8, 2013 | 10:16 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Something is corrupting the serial data line.. Either a wet/ corroded BCM OR a wet/corroded/damaged seat connector or door connector with damaged bent/deformed female pins.
Find the serial data connector to the LEFT of the BCM and pop the top of the one with four wires and see if the issue resolves it self. that will tell you if its the seat, LDCM or RDCM
Bill
To Assistance Please... ERR Codes, Beeps, Lights (Video + Codes)
