A/C Clutch Plates Squealing
Old Jun 6, 2013 | 09:50 PM
jlaw1313@comcast.net's Avatar
Default A/C Clutch Plates Squealing
Rebuild or replace entire compressor?
Old Jun 7, 2013 | 12:03 PM
TNX ZORA's Avatar
TNX ZORA
Did you verify full battery voltage at compressor clutch? On the venerable GM A6 compressor you could replace the clutch without removing the compressor. Don't know about the C5 compressor.
Old Jun 7, 2013 | 10:07 PM
No I did not verifiy voltage at the compressor. The compressor clutch plates squeal when the A/C is off. Pulling out the service manual now. Thanks.
Old Dec 22, 2013 | 09:13 PM
Ahmer's Avatar
Ahmer
I have the same problem. I went ahead and sprayed PB blaster on the inside of the clutch and that seemed to have quieted things a bit.
Old Dec 22, 2013 | 10:05 PM
1999corvettels1's Avatar
1999corvettels1
I just learned something here, my mom's Grand Am the A/C compressor was squeeling, I first smelled a burning smell.
Then it quit working altogether(not pumping according to gauges), I was going to replace the compressor this coming spring, I never thought about testing to see if it is getting full voltage.
That would suck to put on a new compressor and find out it was a voltage issue!
Thanks for the idea.
To A/C Clutch Plates Squealing
