c5 not starting.. code P1631 H
Old Jun 8, 2013 | 05:54 PM
Boosted93's Avatar
Boosted93
Default c5 not starting.. code P1631 H
Hey guys my c5 likes to randomly not start.. I pulled the codes and the one that stands out after researching everything is P1631 H.. I dont have key fobs for my car so i was thinkin it had to do with unlocking it and locking it sometimes.. but it happens so random that its hard to tell
What should my next move be? Ive got a new key made and still the same thing.. Someone help me out please
Old Jun 8, 2013 | 05:55 PM
Boosted93's Avatar
Boosted93
Forgot to mention that sometimes if this happens and i wait three mins it will start.. but sometimes it takes up to 20 mins
ohhh and it seems to happen the most in the summer
Old Jun 8, 2013 | 06:17 PM
Boosted93's Avatar
Boosted93
Originally Posted by 8VETTE7
Lots of potential causes for C5's not starting including Security related problems as P 1631 might indicate.
What other codes do you have??? Have you cleared all the codes? If so what codes come back after you clear them???
When the car will NOT start, what is happening to the security light on the dash??? ON solid?? Flashes??? OUT???? Comes on and then goes out??????
the security light just stays solid.. Ive cleared the codes but didnt see what came back..
other codes are
PMC:p1571 h
BCM: b2527 HC
Hvac: B0333 hc
Old Jun 8, 2013 | 06:57 PM
Boosted93's Avatar
Boosted93
Key is not being read correctly. If you have replaced the key then the problem likely lies with the sensing wire in the lock cylinder. These get a layer of oxidation on them over the years or get damaged by key insertion.
You can try the following to clean the wire and it may work:
Get a small aerosol container of electrical contact cleaner. (For certain Radio Shack will have this but many parts stores have it also. Spray some into the lock cylinder and then insert and remove the key a dozen or so times wiping the key off with a clean lint free cloth. Repeat if necessary.
If this doesn't clean the sensing wire that contacts the resistor pellet on the key to read it, then your choices are two:
1) Replace the ignition cyclinder.
2) Bypass VATS.
I personally would do #1 if the cleaning fails to correct the problem.
how would I bypass the VATS... Ive tryed cleaning it in the pass with no luck... If i replace the ignition cyclinder will i need to change keys also?
Old Jun 8, 2013 | 07:03 PM
Boosted93's Avatar
Boosted93
Im searching the VATS bypass any reason why you wouldnt do it?
Old Jun 8, 2013 | 07:11 PM
Boosted93's Avatar
Boosted93
Yeah been reading up on the bypass i think i will try it.. any price range for new ignition cylnder?
Old Jun 8, 2013 | 07:22 PM
Boosted93's Avatar
Boosted93
YES, car can now easily be stolen with a screw driver. With VATS, the car cannot be started unless the resistence value of what is in the cylinder matches what is stored in the BCM and PCM. (As you are well aware. )
Good thing I live in idaho lol I think i will try and bypass it
Old Jun 8, 2013 | 07:25 PM
Boosted93's Avatar
Boosted93
I've read recent posts where members have found them online for about $70. I think that Amazon may have them available but don't remember for certain if that was where they were found.
These guys seem to sell them pretty cheap.. im just tired of this issue and dont know why its worst in the summer..
http://forums.corvetteforum.com/c6-p...l?forum_id=115
Old Jun 8, 2013 | 11:02 PM
Boosted93's Avatar
Boosted93
I would check with them. That's a 2005 post.... Same deal MAY NOT still be available.
I would also check out the ignition switch. The diagnosis is easy if you have and can use a Digital Multi Meter (DMM). Certainly I'd do the diagnosis before I spent any money on parts..... JMHO.
alright man thanks for the advice and info! your a big help
To c5 not starting.. code P1631 H
