Guess my dyno numbers
Old Jun 9, 2013 | 12:19 AM
reactor2's Avatar
reactor2
Default Guess my dyno numbers
I'm going to be putting my vette on the dyno in a few weeks. Anyone care do guess my RWHP?
Here's what I have:
'04 A4 Coupe
Engine
1) Dart Pro 1 205cc Heads (10.9:1 compression)
2) 228/232 .571/.578 112LSA cam
3) Fast intake
4) LS2 TB
5) BBK shorty headers
6) Yella Terra rockers
7) P1SC with 4.25" pulley (around 5-6PSI)
Trans/diff
1) Yank SS3600
2) Z06 3.42 rear
Exhaust
1) Z06 titanium
That's the main stuff anyway. What do you think I'll put down?
Old Jun 9, 2013 | 11:34 AM
RonSSNova's Avatar
RonSSNova
580....SWAG!
I bet it feels pretty dang good!
Ron
Old Jun 9, 2013 | 01:54 PM
Water_Walker's Avatar
Water_Walker
Old Jun 9, 2013 | 08:29 PM
DIXZ's Avatar
DIXZ
Old Jun 11, 2013 | 01:00 AM
NukeC5's Avatar
NukeC5
Remember, higher gear ratio and a stall converter make a car show less on the dyno. But Its still going to be very impressive Im sure. My guess is in the 550whp range.
Old Jun 11, 2013 | 07:44 AM
NSTG8R's Avatar
NSTG8R
12hp and 18 lb-ft. Happy Motoring!
Old Jun 11, 2013 | 10:15 PM
reactor2's Avatar
reactor2
530 would be awesome! Next question, how long is that stock A4 going to last? I did install the biggest b&m plate cooler that would fit.
Old Jun 11, 2013 | 11:55 PM
NukeC5's Avatar
NukeC5
Here's where the higher gear ratio and stall have another positive effect. They make life easier on the drive train. I do think it would be wise to invest in a solid trans mount to avoid wheel hop, and a trans to diff brace for strength with that kind of power. But I think it will hold up fine. I am on a similar track with my mods as you are and plan to run the stock A4.
Old Jun 12, 2013 | 10:19 AM
David426's Avatar
David426
Depends on the Dyno.. Between 500-600rwhp
Old Jun 12, 2013 | 12:01 PM
PNW Vett's Avatar
PNW Vett
St. Jude Donor '13
Okay, I'll bite....517 rwhp
Old Jun 13, 2013 | 09:32 AM
kvac's Avatar
kvac
547 rwhp
Old Jul 11, 2014 | 11:31 PM
reactor2's Avatar
reactor2
So I never brought the car to the dyno, I just decided to tune it myself. Its a bit of a learning curve and I'm a long way from being an expert but I enjoy tuning the car as much as I enjoy working on it so why let someone else have all the fun?
I'm running 345/35/18s w/A4 and car won't hook at all at in 1st, so I don't even try (they aren't drag radials so I don't expect much bite). If I lay into it slowly in second (which takes me past 70mph) I can get traction, but on a cool day it will break loose pretty easy as well. I haven't spent much time in 3rd other than to verify AFR (11-11.2) under load.
Max boost in somewhere between 5-6psi with the 4.25" pulley. Id like to pulley down but I really am pushing my luck with that stock tranny the way it is. Plus tuning on the street sucks.
I suspect with drag radials and a strong tranny it should run high 10s. Enough for now (not really). Next stop:
1) RPM transmission
2) Max boost the P1SC (9-10psi?)
3) Meth injection
700 whp anybody?
To Guess my dyno numbers
