Name that part...
Old Jun 24, 2002 | 09:21 PM
3BVert's Avatar
3BVert
Default Name that part...
I found this laying neatly under the front end of my car (in the garage).
Obviously it's some kind of fastener, but where did it come from? For those of you that know every nut, bolt and crappy plastic fastener on their car, can you tell me where this should go?
Specifics:
Head is 3/4" in diameter and it's 1 1/4" long
TIA
[Modified by 3BVert, 7:22 PM 6/24/2002]
Old Jun 24, 2002 | 09:28 PM
allanlaw's Avatar
allanlaw
Default Re: Name that part... (3BVert)
I'm going to guess it's one of those things that holds the cover on underneath your hood.
Old Jun 24, 2002 | 09:29 PM
3BVert's Avatar
3BVert
Default Re: Name that part... (allanlaw)
My first thought too, but they are much bigger.
Old Jun 24, 2002 | 09:34 PM
CHJ In Virginia's Avatar
CHJ In Virginia
Probably from one of two places 1) one of the fasteners that hold hood insulation in place 2) holder for one of the wiring looms in the front of the body. Not a biggie, visually check to see if anything is loose.
Old Jun 24, 2002 | 11:16 PM
NassyVette's Avatar
NassyVette
Default Re: Name that part... (CHJ In Virginia)
Two of those press into female ends and hold the panel above the passengers feet up. ;)
Old Jun 24, 2002 | 11:29 PM
3BVert's Avatar
3BVert
Default Re: Name that part... (NassyVette)
ohhhh... very close, but the head on those is bigger. Made me look though!
It almost looks as if this was an "extra" part left in my engine compartment at the factory. There's not a spec of dirt on it, so it must have been higher up in the engine compartment, and it is in pristene condition (e.g., doesn't look as if it was ever inserted or pulled out).
[Modified by 3BVert, 9:33 PM 6/24/2002]
Old Jun 25, 2002 | 01:30 AM
ROD BROWN's Avatar
ROD BROWN
Thats easy.It holds the Fu Fu valve in place so the gizmo doesn't go beserk. Seriously,I haven't got a clue. :chevy :chevy :flag :chevy :chevy
Old Jun 25, 2002 | 01:53 AM
L.A.P.D.'s Avatar
L.A.P.D.
Supporting Vendor
St. Jude Donor '03-'04-'05-'06
3BVert,
It looks like a push in retainer. They don't easily fall out, so that is weird that it would be just lying there.
Could it have fallen out of the interior of the car?
Shawn
Old Jun 25, 2002 | 03:37 AM
BigBlue's Avatar
BigBlue
Default Re: Name that part... (L.A.P.D.)
It holds the kanooter valve in place so you can take out the muffler bearings with the 1/4" shaddick.
Old Jun 25, 2002 | 08:24 AM
jtk30093's Avatar
jtk30093
I believe it plugs into the center of your power steering pulley!! Mine has worked its way out occasionally and I just "PUSH" it back in. Hope that helps.
Old Jun 25, 2002 | 10:31 AM
Tally Ho's Avatar
Tally Ho
From: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
It could very well be extra. I found an extra cap that goes to the headlight assembly laying in the engine compartment near the radiator. No missing caps and no work done on the car in that area so it must have been extra.
Old Jun 25, 2002 | 10:37 AM
Umrswimr's Avatar
Umrswimr
From: Overwhelmed as one would be, placed in my position.... DFW, TX
St. Jude Donor '05
It's the blinker fluid drain plug. Your blinkers probably no longer work. :D
Old Jun 25, 2002 | 02:36 PM
3BVert's Avatar
3BVert
Default Re: Name that part... (ROD BROWN)
Maybe my car is leaking plastic fasteners... has anyone seen a TSB on that? :lol:
Anyway, no biggie. I'll keep it in the console until I find where it goes or get tired of looking at it.
Old Jun 25, 2002 | 02:44 PM
Z06 Mike's Avatar
Z06 Mike
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Hey...I bet you will see at least 5rwhp loss though.... :lol: :lol: :lol:
Old Jun 25, 2002 | 05:16 PM
NoRice4Me's Avatar
NoRice4Me
It looks like the plastic fastener that attaches the front quarter panel in the wheel well. My car came with a couple missing, so the parts dept gave a couple of those to push in. Had to turn the wheel out to get the forward one in, as there's not much room when the wheels are pointed straight ahead.
Old Jun 25, 2002 | 10:12 PM
Sixguns's Avatar
Sixguns
Default Re: Name that part... (jtk30093)
Yep, this same question comes up often. Its out of the PS pulley.
Old Jun 25, 2002 | 10:37 PM
3BVert's Avatar
3BVert
... And the winner is jtk30093
It just took a little reinforcing post from Sixguns to convince me to go look at it.
Whodathunk it?
Thanks!
To Name that part...
Old Jun 25, 2002 | 11:27 PM
NoMercy's Avatar
NoMercy
Default Re: Name that part... (Umrswimr)
:lol: :lol: :lol: :cheers:
Old Jun 26, 2002 | 11:21 AM
c5chris's Avatar
c5chris
from your stock airbox perhaps??
Old Jun 26, 2002 | 11:30 AM
COOL Z06's Avatar
COOL Z06
....:rolleyes: ........or maybe a push fastener for your fan shroud???
:confused:
