Proving that even simple jobs can go terribly wrong, today while changing the differential fluid the plastic end of my fluid pump blew into the differential fill hole. It is about an 1" x 3/8" and hollow.
I can't see where it went, I can't feel it near the holes. I've tried fishing around from the drain for it with a thin wire, but still no luck. I pushed another quart of gear oil in hoping to wash it to the drain, but no luck. Next, I'm going to fill the differential and pull the drain and hope it gets sucked toward the exit.
Any ideas on how to recover it? I've never had the differential apart. Can you see any of the sump by removing the rear cover? If I pull a half shaft cover, can I see the sump from there?
This really sucks. I was nearly prepped for a track day Monday.
wow that sucks man..i hope you get it out...sounds like my luck, you need one of those little snake cams you get at home depot, I got one and it has saved me tons of time on projects
I have one. I didn't help. I need something much thinner like a fiberscope with a remote head pivot. Once I got the camera in the hole, there's not enough depth to bend it. It needs something like a "right angle" mirror so I can look around.
I'm going to take another stab at it tomorrow with some other ideas and see if I get lucky. I needed a brake from the gear oil fumes.
I really wish you the best on this, but I think that reaching it from the drain plug is a LONG SHOT! I do believe that taking off the right side cover will give you the access you need to get your filler out.
I doubt it would hurt the diff to run it but it's your car and your call. Me, I'd likely just run it for a bit on the stands and change the oil again to flush out the ground up pieces.
You sir, are braver than I. I could just imagine some little piece of plastic lodging its way into the Posi unit...
What it may do to the clutch pack and roller bearings are the only reason I am still trying to get the dang thing. I may resort to chewing it up and hoping for the best. Tonight, I tried a fill and drain a couple times. I did some fishing. I tried both suction on the drain and air pressure through the fill while rotating the tire slowly.
I only have one idea left. I'm going to try to use a pump to circulate the gear oil from a clean drain pain back into the inlet and let it run for a while.
Part of me keeps saying it is soft plastic and it will be mulched, then melted on a road course Monday. The transmission will see 260. I have no clue how hot the differential gets. I'm mostly concerned about a catastrophic failure. The differential has been whining a bit, but I thought I had a couple seasons left.
It is your car and in the end you will do what you think is best.
I have built a few differentials and if I were going to be driving on a road course I would not want foreign material in my differential at 120+! It probably won't hurt anything, but I would be sweating bullets all day long.
You can have the right side cover off in about an hour and a half. A small tube of anaerobic sealant and you are back in business!
But Honey,,,,,,,,,, It blew on the way to the track... The only replacement I can fine is DAMN rebuilt unit. Some guy on the Forum "RKT56" has one on SALE for an EXCELLENT SAVINGS..
I will sacrifice and settle for a "REBUILT" replacement so we can save money!~. Its a GOOD thing that I didn't have to get a new GM replacement..
Be Safe!
LOL Thats the best reconnendation yet and you can remove it IN PLACE!
Be Safe!
All the pictures I've looked at made me think I had no chance coming in from the side. I'd certainly spend a couple hours giving it a chance with a little guidance. I'm guessing I treat it just like I was replacing the cover seal.
( I was actually thinking DTE and a Quaife, but don't tell the wife! )
As DIXZ expected. The nozzle was laying there inside the right side cover. Once I found some decent photos of the inside and saw where the drain hole was in relationship to the ring gear, I realized there was no way I was going to push it through the small gaps.
I was fortunate. My dealer had 1 o-ring and 1 seal in stock. Getting that side cover off is a major pain. I ended up moving the muffler out of the way, so I need to pick up a gasket for it tomorrow and go for a test ride.
