a little advice
Old Jun 11, 2013 | 04:39 PM
didntdoit11's Avatar
didntdoit11
St. Jude Donor '12
Default a little advice
how does this sound for my motor build im looking for around 450hp then i will spray it
ls1 short block clevite main/cam/rod bearings and sealed power rings
CNC 64cc heads 243 castings
Custom ground cam
PAC 1218 springs
Chromoly pushrods
ARP head bolts ls1 style
MLS head gaskets
high pressure oil pump
forged pistons
Stock rocker assy
ls7 lifters
ls2 timing chain
ls2 cam sprocket
lifter trey set ls2
anything im missing
Old Jun 11, 2013 | 05:20 PM
jeff keyuk's Avatar
jeff keyuk
You can get that ,without touching the block. Are you doing the work your self, There are special tools needed!
Old Jun 12, 2013 | 05:15 AM
didntdoit11
St. Jude Donor '12
no im not doing it myself
Old Jun 12, 2013 | 03:03 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Custom ground cam
PAC 1218 springs
Chromoly pushrods
MLS head gaskets
forged pistons
Stock rocker assy
ls7 lifters
ls2 timing chain
ls2 cam sprocket
lifter trey set ls2
anything im missing
Hmmmmmmmmmmmmmmmmmmm,,,,, The ONLY thing in your build that is going to add HP/TQ so far are the Heads & Cam.
What size cam???
What will be the compression ratio???? I have Patriot Performance Ported Stage 2 heads 12.5:1 Cr with bigger intake valves, Ti retainers.
I have an 02 Z with 450 RWHP.
Here are some things that you should be installing or doing:
Reliablability up-grades:
New rocker trunions (COMP CAMS)
Use the ARP HEAD STUDS (MUCH BETTER)
New dampener I used Powerbond. Recommend pinning the damper to the crank! I used the ATI Pinning kit on the Powerbond damper with the key way in the damper hub.
If you use a fast intake, MAP Relocation kit
LIFTERS! DONT SKIMP If you dont like the LS7 lifters (some dont) use some of the new linked lifters.
NOTE, use a PUSH ROD Measuring tool to get the CORRECT lifter preload!!!!!! DO it once do it right do it the first time!
NOTE!! You need a HIGH VOLUME Oil Pump!!!!!! Not high pressure, I used a melling unit.
Horse Power stuff!
New 36 or 42 lb/hr injectors. I used the 42s and they worked out excellent. Your tuner will be able to tell you if 36s are adequate.
FAST 92 intake I ported my own FAST 90
90mm TB (for the FAST Intake)
VARARAM Cold air Intake
PROFESSIONAL TUNE!! Who is doing your tuning?
Long Tube SS HEADERS,, You didnt say if you had then. I coated mine!
If your block has the holes between the timing chain for the timing chain dampener, purchase and install the dampener! Sort of more reliability stuff!
If your car is anything like mine and it still has the stock clutch,, it will MOST LIKELY start sticking to the floor on your FIRST full throttle pass!! Thats what mine did. Sort of more reliability stuff!
I now have a SPEC Clutch/ TICK Master and all new clutch components. Sort of more reliability stuff!
Install a REMOTE CLUTCH SLAVE BLEEDED! Sort of more reliability stuff!
Rearend
It will need to be strengthened if you have any type of tires that grip!.
- C5, ragtopws6 , Upgrading your C5 rear with C6 Z06 guts, : http://forums.corvetteforum.com/c5-g...-z06-guts.html
- C5, Its_Go_Time, Output Shaft Install - Left and Right: http://forums.corvetteforum.com/c5-t...post1573407966
- C5 Differential Seal replacement: http://forums.corvetteforum.com/c5-g...on-photos.html
TORQUE TUBE!!!
Tear it down and examine the rubber couplers now. If you dont, you will shortly after your engine install! If the rubber couplers are cracked or deformed, REPLACE THEM! The stock rubber ones will work FINE!
Lets see,,,,,,,,,,, Been there,,, DONE that,, still have the greasy bloody torn T shirt!
Bill C
Old Jun 13, 2013 | 05:14 AM
didntdoit11
St. Jude Donor '12
What size cam???
Horse Power stuff!
Rearend
TORQUE TUBE!!!
Bill C
thank you Bill
I have a
rpm stage 6 trans
3 inch dls drive shaft
stage 3 rear diff 342 gears
did you go underdrive balancer?
thanks for the info on the oil pump
thanks
jason
Old Jun 13, 2013 | 06:41 AM
helga203's Avatar
helga203
What size cam???
Horse Power stuff!
Rearend
TORQUE TUBE!!!
Bill C
Do you hav any pics of what area of the intake you removed and how much???????
Old Jun 13, 2013 | 07:18 AM
baxsom's Avatar
baxsom
my 00 couple dynoed right at 450 rwhp. To get that we did the PRC 5.3l CNC heads shaved .030 with a cometic thin gasket to raise compression to 11:1, a TSP 228R cam, FAST, and long tubes. All we needed was 30lb injectors and stayed well under the 85% threshold.
Old Jun 13, 2013 | 10:40 AM
NukeC5's Avatar
NukeC5
I agree with Bill. First thing I thought when reading the list was, "these are all rebuild parts" with exception of the ported heads and the cam. The cam will be the deciding factor so we would need the specs to make a call on it. You will need a good intake and exhaust supporting the build to make 450 at the wheels.
Baxsom sounds right on the money
Old Jun 13, 2013 | 01:03 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
YES I DO!
I paid $750 for my New Fast 90 manifold and could NOT see spending close to that to again to have it ported. SO,,,,,,,, I decided to do the porting myself.
First thing that you have to realize is The DAMN THING IS PLASTIC and material comes off at an alarming rate if you are NOT CAREFUL!
Luckily, I was careful and conservative. The FAST 90/92 is constructed from three parts: Top Cover, inside runner divider and the base. Most of the porting is done on that inside runner part and the base at the openings for each intake port. I do some smoothing in the TB Opening but not too much.
I tried to post pics from work BUT,, it wont work properly so, I will add pics later tonight when I get home.
Bill
To a little advice
