Oil Temperture on a C5?
Old Jun 25, 2002 | 08:29 AM
Billy Boguski's Avatar
Billy Boguski
Default Oil Temperture on a C5?
I have a new 2002 convertible, 6 speed. My oil runs hotter than the water. In traffic it gets up to 212-220 degrees. The water temp is about 192 to 210. Is this normal? I have only 600 miles so far.
Old Jun 25, 2002 | 10:00 AM
Jim 47's Avatar
Jim 47
Default Re: Oil Temperture on a C5? (Billy Boguski)
Yes Billy, those temperatures are completely normal for "normal" driving. If you go up a prolonged hill you should see those temperatures go up, and if you go down a prolonged hill you should see those temperatures go down. Happy motoring. :cool:
Old Jun 25, 2002 | 01:14 PM
carpe dm's Avatar
carpe dm
Sounds normal to me; the oil will (or should) always run warmer that the coolant. I'm always happy to see my oil go over 212 for awhile, because then I know I am boiling off any condensation that may have entered the crankcase. :yesnod: :)
Old Jun 25, 2002 | 09:01 PM
Billy Boguski
Default Re: Oil Temperture on a C5? (carpe dm)
212 degrees........water (condensation) water boiling.....never thought of it that way!
Thanks, Billy
Old Jun 25, 2002 | 09:11 PM
MikeV's Avatar
MikeV
Remember also that with summer temps increasing, so will your coolant temps and to a lesser extent other temps.
Old Jun 25, 2002 | 09:31 PM
quenchmasterc5's Avatar
quenchmasterc5
Default Re: Oil Temperture on a C5? (MikeV)
It's also why GM recommends Mobil 1.
Old Jun 26, 2002 | 07:20 PM
Billy Boguski
Default Re: Oil Temperture on a C5? (quenchmasterc5)
Thanks to you all. I am a little "careful".
As you can see by my sig I have a 1967 327. Within 24 hours of getting the new Corvette, the 1967 overheated and blew. I still need to pull the engine to determine the damage. It was so fast, I could not get off the highway. I saw the temp climbing, tried to find a safe place, and within 3 miles, rods were knocking. So now you understand my concern............
Billy
PS I think she was jealous and wanted attention! :yesnod:
Old Jun 26, 2002 | 08:04 PM
GTB's Avatar
GTB
Oil Temp is what I always have on my DIC. I like to see it at least above 180 before I do much revving, and really like to see it close to 212.
Old Jun 26, 2002 | 10:24 PM
Mark VerMurlen's Avatar
Mark VerMurlen
Default Re: Oil Temperture on a C5? (GTB)
If you ever take your car to the track, 280 degrees for the oil is fairly typical and no cause for concern. So you can see that oil in the 210 degree range is pretty tame and as others have told you, quite normal for street driving.
- Mark
To Oil Temperture on a C5?
