oil leak somewhere advice
Old Jun 17, 2013 | 06:14 PM
cjragonese's Avatar
cjragonese
Default oil leak somewhere advice
I have a 2000 C5. While having the AC worked on I was told I have an oil leak. Its a very small oil leak because I rarely ever see a drop of oil on the garage floor. However I was shown the underside and the oil pan has residucal oil on it. The pan itself isnt leaking. Ive been told its the rear seal (bearing)?? I have also noticed that my oil pressure gauge is reading low. cold it runs around 70, warms up it will drop to 50 and idle is around 40. Could I have a leaking oil pressure sensor? I have vnoticed a faint smell of burnt oil on occassion not strong and not always. Also I put around 1/2 qt in the engine between oil changes and this seems. Havent seen an abnormal engine oil drop. Of course NAPA would love to charge me around $2000 for the job. Any suggestions before doing so?
Old Mar 27, 2014 | 10:39 PM
timedwards's Avatar
timedwards
Ever solve your problem?
