Service Active Handling
Old Jun 17, 2013 | 06:56 PM
MagsMom's Avatar
MagsMom
1st Gear
Default Service Active Handling
New to Forum and new owner of a C5 2001 Corvette with 47k miles. Couple of days ago I was out, turned engine off, then when I restarted "Service Active Handling", "Reduce Engine Power", and Service Traction System" all came up & my power was greatly reduced. Codes cleared & The following are now what comes up on codes: Under BO-RFA, codes U1000H & U1064H; 10-PCM codes are P1220HC & P1221HC; Under 28-TCS U-1301H, C1221H, C1222H, C1248H, 1278H, & 1292H; Under 40-BCM is the code B2723H. I need some help as to what direction to go.
Old Jun 17, 2013 | 07:26 PM
3boystoys's Avatar
3boystoys
When I see a lot of unrelated codes I look at the accordion tube in the doors FIRST.
