finding TDC to set valves?
Old Jun 19, 2013 | 04:02 PM
Tar Heel's Avatar
Tar Heel
Default finding TDC to set valves?
New cam is in and now I need to find TDC to adjust the valves. If I'm not mistaken you turn the engine over by hand until you get the exhaust to come out of cylinder #1. When this happens will the dot on the cam sprocket be down at the 6:00 position and the dot on the crankshaft sprocket be up at the 12:00 position? I understand you adjust half of them to 22 ft. lbs. of torque (I have the list of which ones) and then you turn the engine over 360 and do the rest. However, from some research that I've done one post said that both dots will be at 12:00 which didn't sound correct to me.
Thanks.
Scott
Old Jun 19, 2013 | 04:11 PM
ZeeOSix's Avatar
ZeeOSix
Unless you have adjustable rocker arms, there is no adjustment on the OEM rockers. You control lifter pre-load with the length of the pushrod.
The trunnions of the rocker arms are torqued to 22 ft-lbs ... period. No adjustments unless you are using aftermarket rockers where you can adjust lifter per-load.
There's a page out of the service manual that has been posted a 100 times on this board over the years that shows where the crank needs to be when torquing the rockers to 22 ft-lbs. Object is to torque them down when the valve is closed.
Old Jun 19, 2013 | 04:13 PM
racebum's Avatar
racebum
Old Jun 19, 2013 | 04:15 PM
dblerman's Avatar
dblerman
At TDC, both valves on cylinder 1 will be CLOSED.
Old Jun 19, 2013 | 04:16 PM
ZeeOSix's Avatar
ZeeOSix
^^ now it's been posted 101 times.
Old Jun 19, 2013 | 05:08 PM
Tar Heel's Avatar
Tar Heel
That's the post I'm questioning. How would the dot be up at 12:00 when the dowel for the cam pin is at 3:00? When I reinstalled my cam sprocket the dot is down and the dowel is to the right. I'm using the OEM chain and sprockets.
By the way, I've never understood why people take the time to post "it's been discussed 100 times ... look it up". I had the post and knew what it said but was questioning it. I believe the old saying goes if you have nothing good to say don't say anything at all. You folks without anything helpful to add get old and make using the forum to do research frustrating. Just my 2 cents.
Scott
Old Jun 19, 2013 | 05:57 PM
crimsonwake's Avatar
crimsonwake
Scott
I see what you saying. That picture is kind of misleading. With the crank dot at 12 and the cam dot at 6, the cam dowel should be at 3 o'clock. Rotate 360 degrees and the crank dot should be at 12, the cam dot should be at 12, and the cam dowel should be at 9 o'clock.
Old Jun 19, 2013 | 06:49 PM
ZeeOSix's Avatar
ZeeOSix
Scott
It might help if you explain yourself a little better ... people can't read your mind. Using the term "adjusting the valves" is totally mis-leading, and you never mentioned you were referring to the page in the service manual, or didn't reference it with a link, etc.
Old Jun 19, 2013 | 07:09 PM
Tar Heel's Avatar
Tar Heel
Yes sir, you're absolutely correct. My mistake and my apologies. Adjusting the valves is an incorrect term on this engine. I'm trying to put the rockers back on correctly after a cam install.
Thank you and again I apologize.
Old Jun 19, 2013 | 07:13 PM
Tar Heel's Avatar
Tar Heel
Ok, now I'm really confused. I'm a HS math teacher and am off for the summer so I must have my "summer brain" working now.
So where is TDC? With the cam dot at 6 and dowel at 3
OR
with the cam dot at 12 and the dowel at 9?
That picture from the service manual doesn't seem correct to me.
Scott
Old Jun 19, 2013 | 08:09 PM
ZeeOSix's Avatar
ZeeOSix
TH - I'd go by the crankshaft key at the 1:30 position as the SM described in Step 6. Forget about the dots on the crank and cam sprockets in the SM figure at this point.
To verify, put the pushrods in the lifters on Cyl #1 and watch the intake pushrod go up (intake valve would be opening), then back down (intake valve would be closing) as you rotate the engine. The piston is on the compression stroke after the intake pushrod stops moving downwards. Bring the piston to TDC and you are there. The crank key should be at 1:30 then if the SM is correct.
Old Jun 19, 2013 | 08:11 PM
crimsonwake
OR
Scott
Haha, both actually. TDC is in reference to the crank position: Crank dot will always be at 12 for cylinder 1 TDC (and cylinder 6). The cam is dot location is just in reference to whether #1 cylinder is TDC compression or TDC exhaust. Either way #1 is at TDC. From there follow the GM rocker torque procedure.
dblerman's Avatar
dblerman
OR
Scott
Ignore the cam dowel.
There are two top dead centers. One on compression stroke, and one on exhaust stroke. You want to start the process from the FSM at TDC compression stroke, which is cam sprocket and crank sprocket dot 12 o'clock.
Old Jun 19, 2013 | 09:13 PM
Tar Heel's Avatar
Tar Heel
Thanks guys. I think I have it now. How does this all sound?
1. The OEM cam sprocket has a small "half circle" on it and is also stamped "12" at that spot. When you install the cam this "dot" will be at 6 (making the stamped "12" upside down), the crank dot is at 12, and the dowel pin is at 3.
2. To get to TDC rotate the "12" to the top putting the dowel at 9. This is always the compression stroke. Both #1 valves are closed.
3. After you install and torque the proper rockers (including both #1s) turn the CRANK 360, which will bring the "12" on the cam sprocket to 6, and do the rest (including both #6s).
Sorry to be so confusing and ask so many questions but I enjoy learning new things and this is the first time I've done a cam in a LS1. Other than having someone install the ring and pinion (after we took them the differential), we've done everything on our own on this including a converter, cam, header, etc. install in our 2-car garage.
Scott
Old Jun 19, 2013 | 09:14 PM
Tar Heel's Avatar
Tar Heel
I like this method but I'm having trouble seeing the crankshaft key with the oil pump still on. Should I be able to see it?
Old Jun 19, 2013 | 09:38 PM
dblerman's Avatar
dblerman
You should be able to. I know I was able to when I had my oil pump on...
Old Jun 19, 2013 | 09:44 PM
dblerman's Avatar
dblerman
I took this picture right after I took my timing cover off...To give you an idea, I'm about 20 degrees past TDC compression stroke. And you can see the crank sprocket key too.
To finding TDC to set valves?
Old Jun 19, 2013 | 10:23 PM
martysauto's Avatar
martysauto
St. Jude Donor '14
I just did this job. One thing nobody mentioned was pushrods length/lifter preload. It's very important. You could have lifter damage, valves hanging open or at minimum a noisey engine. I did a lot of Internet searching and got conflicting specs so I called Texas speed and they told me .035-.085 preload is acceptable. .050-.070 is preferred.
I used a comp cam adjustable pushrod to check it on 2 valves per head. I also checked with a dial indicator. I was at .095 preload with the 7.400 pushrods. I had tsp overnight me a set of 3.375's and rechecked, .070 good to go. It took me a while but I would rather be safe and didn't want to take it back apart.
The car should be all completed early next week. I'll let you know the final results.
Old Jun 19, 2013 | 10:52 PM
Tar Heel's Avatar
Tar Heel
Thanks; good point. I had Bullet cam grind a Stocker cam which has stock lift and stock duration. My understanding from doing research is that if the base circle is the same on the new cam then the stock length 7.400 pushrod should be fine. If the lift wasn't increased I would think the base circle should be the same.
Old Jun 20, 2013 | 09:00 PM
Paul 75 L82's Avatar
Paul 75 L82
