Headlights won't shut off?
Old Jun 20, 2013 | 12:05 PM
crosstheline's Avatar
crosstheline
Default Headlights won't shut off?
I washed the car yesterday and I got water on the fuse panel inside the engine bay. Now the headlights won't shut off even in the retracted position and even with the key removed. The tail lights are off just the headlights stay on. I removed the fuse so that the battery won't drain down and put the fuse in after around 10 hours hoping it may have dried out. No luck.
Anyone believe it is just a "wet" issue or something else?
Old Jun 20, 2013 | 12:14 PM
ls1k5's Avatar
ls1k5
Check the headlight module and connector which should be under the right headlight.
Old Jun 20, 2013 | 02:56 PM
crosstheline
Can I get to it without removing the headlight?....thanks
Old Jun 20, 2013 | 07:07 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
test if it will shut off with twlight mode on.
I had to replace my headlamp column switch as a pin/cable had a short at the plug in the steering column.
http://forums.corvetteforum.com/c5-t...-a-how-to.html
Old Jun 20, 2013 | 08:47 PM
guido7834's Avatar
guido7834
I'm curious how water could be the problem. I was my engine and never had a problem.
Old Jun 21, 2013 | 01:50 PM
ls1k5's Avatar
ls1k5
I'm not sure, I've never had to mess with mine but the wiring diagram shows it controlling the headlights.
Looking at a 2000 diagram, the body control module turns the ALC HDLP relay (44 under passenger floor mat) on and off. I have been having problems with my headlights not turning on immediately and bypassing relay 44 makes them work right so pulling that relay should shut them off. There is a head light off input to the BCM that would be worth checking.
Old Jun 21, 2013 | 02:57 PM
lionelhutz's Avatar
lionelhutz
The module under the right headlight only controls the motors to open and close the headlights.
Try turning off the twightlight sentinal or removing the relay as suggested.
Check and see if the BCM or the fuse box under the passenger toe board shows any signs of getting wet.
Old Jun 24, 2013 | 12:32 PM
ls1k5's Avatar
ls1k5
I think both of our problems are the headlight switch after reading this post and looking at the pertinent wiring diagrams. The AC Delco D1512G switch gets my vote and I'm going to replace the hazard switch at the same time ACDelco 10359036 both from amazon $152.10 shipped. My turn signals don't work occasionally and I have to press the hazard switch to get them working again.
Old Jun 24, 2013 | 12:46 PM
Z06seal's Avatar
Z06seal
I'm having a similar sort of problem.... except my headlights work, but not the motors (they won't go up or down) and I also lost dashboard lights and my tail lights....
thing is, it happened right after I changed a light bulb. how on earth could it have gone bad as I changed a turn signal bulb is beyond me. perfect timing perhaps.
I'm thinking the same with you... how on earth can your stalk go bad when you ended up getting little water in your fuse box? lol
Old Jun 24, 2013 | 06:56 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
Do this as a test. Flip to high beams to test if the lights will pop up.
If they do you have confirmed it is the switch that is the problem
Old Jun 24, 2013 | 06:59 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
sounds as if you have a ground when you changed the bulb and blew a fuse. Check the cable on the tun single lamp as it may have exposed wire causing your issue or the bulb housing melted causing a short.
The "stalk" is a common c5 failure point but may not be your particular issue.
Old Jul 8, 2013 | 03:31 PM
ls1k5's Avatar
ls1k5
I replaced the headlight switch and the hazard switch last friday and now everything works great. I'm getting really good a pulling the dashboard after the problems I had with the passenger blend door motor and the hazard switch.
Old Nov 5, 2022 | 07:53 PM
tommyoneleg's Avatar
tommyoneleg
I know this post was about 9 years ago but did you fix your problem, I have the same problem on my 99, was hoping someone could point me in a better direction.
Old Nov 5, 2022 | 10:54 PM
mmartinez's Avatar
mmartinez
Suggest you open a new post, rarely do you get any replies when posting to an old post.
To Headlights won't shut off?
