Turn Signal issues
Jun 20, 2013 | 02:58 PM
Cruising
Turn Signal issues
Hello All-I have a 2000 C5 with about 25k miles on it. For the past few years, my turn signals [both left and right] intermittently worked. Usually, I can 'trick' them into working by depressing the hazard button. That trick didn't work as of today and the signals are working less and less often. Any ideas/suggestions?
Reason: grammar
Jun 20, 2013 | 03:33 PM
You need to change the hazard light switch and you will be good to go. Very common problem.
Jun 20, 2013 | 03:39 PM
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
I have a switch NIB if you are interested.......I will take $25 shipped for it.
PM me if interested
Jun 20, 2013 | 03:45 PM
Cruising
Quote:
Originally Posted by
reath1
Thank you. The hazard switch located on the dash above the radio [not the turn signal housing on the steering column], correct?
MuscatDetroitC5
yep...
Jun 20, 2013 | 03:46 PM
Cruising
pewter99
PM me if interested
Thank you. Is the hazard switch on the dash above the radio [not the turn signal housing on the steering column, right]?
Jun 20, 2013 | 03:47 PM
MuscatDetroitC5
yes, you can pull the knee bolster down under the steering column and reach up there to grab it
Jun 20, 2013 | 04:00 PM
Cruising
pewter99
Thank you very much! You're a genius!!!
Jun 20, 2013 | 04:01 PM
MuscatDetroitC5
