c5 headlight problem
Old Jun 23, 2013 | 08:27 AM
c.keg's Avatar
c.keg
6th Gear
Default c5 headlight problem
When turning off my headlights, my left one will close and then open 1/2 way and stay there. When I turn them back on it will cycle down first and then open completely. I replaced both side gears with brass ones 6 mo's ago.
Old Jun 23, 2013 | 09:55 AM
lionelhutz's Avatar
lionelhutz
The arm is going past the stop for the closed position. You need spacers between the motor and body so that the arm hits the stops. A couple of washers per bolt should be about right.
Old Jun 24, 2013 | 05:30 PM
c.keg's Avatar
c.keg
6th Gear
Thanks,
New stops and a few washers took care of it.
To c5 headlight problem
