hvac problem-display
Old Jun 24, 2013 | 01:44 PM
uliandros's Avatar
uliandros
1st Gear
Default hvac problem-display
welcome
I have a problem with c5 corvette clima display. because I had a bad contact on the display, I opened it to see the error. awkwardness after I made contact between the circuit board. after reconnecting everything is throbbing. Electromechanics me the error, but the outdoor temperature is showing me from -10 to -32 degrees, resulting in air-conditioning does not work. by the way external sensor works.
code is as follows: B0361HC.B0365H, B0441H, B0446H
but I have another problem
28-TSC
code is as follows: C1221H, C1282HC, C1284HC to C1288, C1296
Does anyone have any solutions?
I'm from Slovenia and in my country is not corvette service.
thanks for the help!
Old Jun 25, 2013 | 02:36 PM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
Originally Posted by uliandros
welcome
28-TSC
Is there anyone local you can swap the AC head unit with to see if its just your head unit having issues ? Maybe you shorted out the board when you opened it.
If its just your head unit, and its having issues then i would ask some of the forum vendors if they have any used ones.
Or order a new one from GM. The Dual Zone AC unit from my 04 Z06 is GM PN 09380441.
Old Jun 25, 2013 | 02:38 PM
Toque's Avatar
Toque
Contact Gene Culley for the correct PN for your car.
He can get you just about anything you need !
http://forums.corvetteforum.com/memb...ne-culley.html
Toque
To hvac problem-display
