2004 C5 overheating
Old Jun 25, 2013 | 10:49 PM
ex9850's Avatar
ex9850
Default 2004 C5 overheating
Suddenly my car started running hot (very hot about 260) ... I slowed down to about 45mph and turned off the the a/c and it dropped to 240 for a while then climbed back up - no steam - drove home about 15 miles (manual said that was okay - of course left my cell phone at home or I would have called a wrecker) and the engine began running at reduced power (DIC came on) - are there things I can test myself or do i need a a service shop to check it out ?
Old Jun 25, 2013 | 10:53 PM
JMBLOWNWS6's Avatar
JMBLOWNWS6
Jump fan relays to make sure fans come on. Reduced power is normal as the PCM is protecting the engine. Look at the front of the radiator/ ac condenser for blockage. If all check out check for bad T stat.
Old Jun 26, 2013 | 04:22 AM
dart.deanda's Avatar
dart.deanda
Quick question. How hot is too hot? Mine runs 220 quite often. The temp always increases at stop signs, noticeably, or in traffic. Do these cars run hot? Not trying to hijack the OP's thread...
Old Jun 26, 2013 | 06:59 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
220 is normal when its hot out if you are in traffic...but you probably still need to clean the radiator etc as it shouldn't do that all the time IMO....some folks say yeah but.....
I just went through some major modifications to cool my Maggie car down and I still don't see 220 and it was a regular thing before that in fact I couldn't use my AC while driving without seeing 240....so much better now.....
GM says these cars run on the hot side but I feel better when I am not seeing 225+....thats just me
Old Jun 26, 2013 | 07:57 AM
runner140*'s Avatar
runner140*
Things to check:
1. Check to see that the radiator cap holds 15 psi.
2. Check/pull the radiator...make sure its clean. Also check the A/C is clean.
3. Change the fluid...do a full system flush....50/50 mix of distilled and
DexCool.
4. Check the hoses.
5. Check to see there is NO air in the system (burped).
6. Check to see the water pump is circulating the fluid.
7. Check and make sure the thermostat is good and not stuck.
The above should keep you busy for a short while.
Get back to us.
Old Jun 26, 2013 | 08:45 AM
Terry Kenkel's Avatar
Terry Kenkel
4th Gear
My issue is when I have the A/C on the car overheats. When I turn the A/C off, the temp goes back down... Is it the coolant, or the fans?
To 2004 C5 overheating
