I know its next to impossible to diagnose problems through forums but I was going to head out on a vacation drive but may be too scared of a motor issue.
01 vert A4 no mods other than Vararam and Corsa axle back 47k miles.
I let the car idle to temperature and no rattle, knock, lifter tick or whatever. A gradual increase in rpm still in park and I get a rattle from the motor from 1100 to 1700 rpm. Once I go above 1700 it goes away. Back at idle it goes away but in that rpm range it sounds bad enough to park it. Any ideas? Lifter possibly?
Your sure its from the motor not a heat shield or something? I would think a Lifter/Rocker/Valve/Ect would occur at all rpms and even more so at higher RPM's. if you cant tell it might be best to have a Mechanic diag it... worth the 40-50$ to know 100%.
Does it rattle in Neutral, In gear or both... and i assume you dont have any codes and you do read oil pressure on the dash.. does it sound like its from the Front, back, left side, right side of the motor or the center? if it changes with RPM then you can know it is most likly rotational... Alternator, PS pump, Idler, Tensioner would be easier to hear from the front.
Thanks Bill. I forgot that my rockers had the Comp Cams trunion upgrade. The noise was there before and after the upgrade but is steadily getting worse. I just pulled both belts and started the car and still get the noise. So no accessory problem. I'll try the power brake trick with a scope shortly. Then I'll pull the valve covers and have a look at the rockers.
Pulled the valve covers and everything looks fine there. Even with the Comp Cams trunion upgrade the rockers have very small side to side movement when there is no load on them. I'm beginning to think that is my noise.
Didn't touch the car today so no updates. Tomorrow I'm putting the valve covers back on and taking it to Speedsouth for their opinion on the noise and talk to them about a cam, headers and a tune and some other goodies.
