Ported and polished TB???
Old Jun 26, 2002 | 11:58 AM
Mike TexaSS's Avatar
Mike TexaSS
Default Ported and polished TB???
How much is this mod worth? Because for 125.00 Bucks it seems like a good idea regardless. Any one have one installed? Any driveability issues?
How much HP have you guys seen on a dyno with this mod.
Hers a pick of a ported and polished TB Does any one have a pic of a stock TB???
Old Jun 26, 2002 | 12:02 PM
RoliO's Avatar
RoliO
Default Re: Ported and polished TB??? (Impala SS Z06)
I've heard anywhere from 5-10rwhp depending on mods done to the car. I've got one coming on soon. :D
Old Jun 26, 2002 | 12:06 PM
MY1Fast99C5's Avatar
MY1Fast99C5
Who does it for $125?
Old Jun 26, 2002 | 12:13 PM
Mike TexaSS
Speed Demon Motorsports ported throttle bodies are an excellent addition to your highly modified LS1 Engine providing more crisp throttle response and more power at higher RPM's! What we do is bore the throttle body orifice to a uniform size, allowing air to pass through unobstructed. We then polish the entire orifice to a high polish allowing air to more freely flow. The end result is a beautiful piece that can produce more power than a stock throttle body.
SDM-LS1TB Custom Ported and Polished Throttle Body for C5 Corvettes (sold on exchange $129.95
Speed Demon Motorsports Houson TX (281) 866-7000
Old Jun 26, 2002 | 12:48 PM
C5Noir's Avatar
C5Noir
Just use a dremel and do it yourself, that's what I did :yesnod:
Old Jun 26, 2002 | 02:45 PM
pkmoose's Avatar
pkmoose
Cruise-In III Veteran
Default Re: Ported and polished TB??? (C5Noir)
:D
Old Jun 26, 2002 | 05:37 PM
dads01dream's Avatar
dads01dream
Default Re: Ported and polished TB??? (pkmoose)
Use a dremel? Were you able to open up the factory diameter or did you simply smooth out all the casting rash? Any dyno #'s show a gain?
I love these "do-it-yourself" type tricks. Used to do them to my Mustang all the time. That car LOVED little mods.!!
Thx
Old Jun 26, 2002 | 06:12 PM
C5Noir's Avatar
C5Noir
Default Re: Ported and polished TB??? (dads01dream)
Yes, you can open up the diameter of the TB, however DO NOT TOUCH anywhere where the TB blade closes. If you dremel that area then your idle will hang and your car will not run properly. Get some grinding stones and polishing pads to smooth out the lip in the TB before you get to the TB blade area and to open in up some. Then polish it up with the polishing pads ;). Works well. No dyno #'s, etc however it was a little peppier when I hit the gas. Unless you have cam and/or heads it wont really matter all that much whether your TB is ported or not.
Old Jun 26, 2002 | 10:23 PM
dads01dream
Peppier is good! Heck, it's just a little something to tinker with on a weekend. Thanks for the tips.
:cheers:
Old Jun 26, 2002 | 11:41 PM
2000^C5's Avatar
2000^C5
From: My barber didn't know when to quit... Do you?
I will be getting one...
To Ported and polished TB???
