Electrical Problems SOS HELP
Old Jul 1, 2013 | 02:48 PM
neiljames777's Avatar
neiljames777
7th Gear
Default Electrical Problems SOS HELP
so I have 2 electrical problems
First, is my brake lights. flashers working, front lights working, blinkers working, the middle 3rd tail light is working but the brake lights are not working....checked the fuse, replaced the bulbs and also replace the brake switch please advice with this issue
Is that isn't enough my passenger power lock isn't working and my window isn't going back up after I put it down...checked fuses as well on this
PLEASE HELP MEEEEE
Old Jul 1, 2013 | 04:07 PM
3boystoys's Avatar
3boystoys
For the window, jiggle the accordian tube between the door and the A-pillar to see if you have a funky connection.
Old Jul 1, 2013 | 04:08 PM
neiljames777
7th Gear
did this and it worked but brake light is still down thinking it might be the Hazard switch or multifunction switch which i heard is not fun to take out
Old Jul 1, 2013 | 04:18 PM
3boystoys's Avatar
3boystoys
Lot's of threads on this, do a search.
Old Jul 1, 2013 | 06:50 PM
lionelhutz's Avatar
lionelhutz
There is a contact in the hazard switch for the brake lights. It's after the switch but before the feed for the 3rd brake light. That's the place I would look first. Try cycling the hazard switch a bunch of times and see if they come back and then you'd know it's the problem.
To Electrical Problems SOS HELP
