ball joint replacement ... alignment needed?
Old Jul 6, 2013 | 09:12 PM
Tar Heel's Avatar
Tar Heel
Default ball joint replacement ... alignment needed?
I'm going to remove the rear spindles to replace the upper ball joints this week. When I get it back together will I need a rear alignment?
Thanks.
Scott
Old Jul 7, 2013 | 02:09 AM
RonSSNova's Avatar
RonSSNova
No. As long as you don't loosen the lower control arm bolts.
Old Jul 7, 2013 | 07:31 AM
Tar Heel's Avatar
Tar Heel
Don't I have to remove those bolts Ron to free the spindle from the car? I don't have a ball joint press and plan to take the spindle somewhere to get the old ball joint pressed out and the new one put in. Or are you talking about where they connect to the car?
Old Jul 7, 2013 | 09:36 AM
etekberg's Avatar
etekberg
I don't see why you would take the spindle off the car. Just remove the upper a-arm.
Old Jul 7, 2013 | 10:09 AM
lionelhutz's Avatar
lionelhutz
No, you will be OK. The alignment adjustment is at the lower a-arm to subframe front bolt and by screwing the tie rod end on or off of the rod. Just removing the spindle by popping the ball studs (lower ball joint and tie rod end) is fine.
Because the ball joint is in the spindle.
Old Jul 7, 2013 | 11:31 AM
etekberg's Avatar
etekberg
Doh! Should have looked at my own picture. I was thinking it was in the a-arm.
Old Jul 7, 2013 | 11:49 AM
LAddams's Avatar
LAddams
It depends. If the alignment was adjusted at some point to compensate for slop in the worn joint, then yes the new joint will throw it out of alignment.
Old Jul 7, 2013 | 12:02 PM
etekberg's Avatar
etekberg
At the risk of putting my foot in my mouth again why not just rent a ball joint press from your parts store and keep the spindle on the car?
Old Jul 7, 2013 | 09:22 PM
bracketshark's Avatar
bracketshark
Why don't you get an alignment after the replacement is installed, then let us all know if it was necessary. I think it is.
Old Jul 9, 2013 | 10:45 AM
3sACROWD's Avatar
3sACROWD
I agree with renting a ball joint press from a part store. AutoZone does it for a deposit only. You get the deposit back when you return the tool.
If you know how to operate a C-clamp, you can operate a ball joint press. The device I rented was just a modified C-clamp type set up. Very easy and effective.
Old Jul 9, 2013 | 08:58 PM
NukeC5's Avatar
NukeC5
The problem that both the OP and I are having is that the OE ball joints rub the inside of our 16" wheels. I shaved mine down too to make them fit, but worry about the integrity of the ball joints a lot now. I definitely cannot afford the smaller spindles made for drag tires. And other ball joints like the ones from Pfadt etc, seem to be even taller out the top of the spindle.
Anyone have any recommendations on this? I am ordering a pair of ball joints just to have on hand in case I have issues. But upon replacement, I would once again not be able to fit my drag pack.
Old Jul 9, 2013 | 10:13 PM
DonP1's Avatar
DonP1
My newly purchased C5 with 93K is in the shop for the first time. They said it needed a new ball joint ($190) and an alignment ($90). I guess I got taken?
Old Jul 10, 2013 | 12:47 AM
RonSSNova's Avatar
RonSSNova
Does the top cap even do anything except cover the top of the ball? I thought guys just whacked it down with a whammer?
You should take it apart and see.
Old Jul 10, 2013 | 02:53 PM
Tar Heel's Avatar
Tar Heel
The top cap holds the shaft, plastic sleeve, and grease inside. After I ground through the OEM set you could grab the upper A-arm and pushing up on it watch the inside of the ball joint come up (causing less clearance).
I bought a set of Moog ball joints and I immediately knew they were taller and going to be a problem. Since I had them here already I had them pressed in and tried the hammering, grinding, fitting, ... and it wasn't even close. Another $100 bill down the drain. This is becoming a pain in the rear.
I'm going to order a set of the LG race spindles and hopefully be done with it. This latest round of mods is getting expensive ...
Also, I've decided to go ahead and get an alignment since I've had so many things apart and adjusted the ride height on the stock bolts several times adjusting for the 28" tires. For less than $100 it's cheap insurance.
Scott
Old Jul 10, 2013 | 02:57 PM
Tar Heel's Avatar
Tar Heel
The ball joint from Rock Auto was $40 but all my local parts store had the same one for no cheaper than $80. Depending on how comfortable you are with a wrench it's not really that bad of a job to change one but I wouldn't say that $190 was a horrible price. High? Perhaps a tad but not highway robbery like some of the prices garages charge. Assuming you have a 33mm socket and the ability to remove the axle nut I took both spindles completely off the car in less than an hour.
Old Jul 10, 2013 | 03:21 PM
DonP1's Avatar
DonP1
Thanks. I wasn't sure and it's my first time at this shop. I didn't feel comfortable working on suspensions or alignment so they did it. I can positively tell the difference for the better (no more erratic stearing), steering is tight, and it goes in a straight line. I'm happy.
I will do my own rotors and pads, and plugs and wires, and I guess a passenger side window regulator now as well.
Old Jul 11, 2013 | 09:57 AM
lionelhutz's Avatar
lionelhutz
It's not too bad a price at all and not nearly as bad as the dealer that wanted $300 for programming the new ABS/TC control module which doesn't require any programming.
To ball joint replacement ... alignment needed?
