How to remove fuel door?
Old Jul 7, 2013 | 01:51 PM
Camss57's Avatar
Camss57
Default How to remove fuel door?
I just picked up an 02 Z06 and it has an aftermarket fuel door on it. It came with the stock door which I would like to put back on. I tried a search and didn't find what I was looking for. Anyone have a link on how to do this? Thanks!
Old Jul 7, 2013 | 04:34 PM
Camss57's Avatar
Camss57
Okay, I got the door on but it would not latch. The "plug" came loose. Does that just twist in somehow? I'm talking about the cable and the latch.
Old Jul 7, 2013 | 09:04 PM
Patches's Avatar
Patches
A nut holds it onto the filler collar.
Old Jul 7, 2013 | 11:53 PM
Camss57's Avatar
Camss57
The nut is still in place, but the plunger and cable came out. Did I break it? If so, can I just get a new cable?
Old Jul 8, 2013 | 04:37 PM
Camss57's Avatar
Camss57
Okay, got it back in and the door closes. It will not open with the button, but it will with the manual release? The button worked before I swapped out the door. Door is flush with the body when it's closed.
Old Jul 8, 2013 | 05:16 PM
Patches's Avatar
Patches
First things I'd check: 1) The fuse on this is easy to pop. I've done it myself. 2) Make sure the connector is securely plugged in on the actuator.
Old Jul 8, 2013 | 10:38 PM
Camss57's Avatar
Camss57
Thanks, I will check those and report back.
Old Jul 10, 2013 | 12:55 PM
Camss57's Avatar
Camss57
Thanks for the help Patches! After I started the car the door button works fine now. I had the same thing happen when I put front door speakers in my G8 GT. The door lock wouldn't work. Once I started the car and put it in gear the locks worked as they should. I don't know if that somehow resets the switch, but it works.
Old Jul 10, 2013 | 03:24 PM
Patches's Avatar
Patches
Nice work!
To How to remove fuel door?
