Clutch lines...
Old Jun 27, 2002 | 01:04 PM
C5Noir's Avatar
C5Noir
Default Clutch lines...
Since there are so many restrictions in our clutch lines from the master to the slave couldn't a shop/tuner/vendor have a custom line made for each route that had just quick clip fittings to connect to the master and slave and would therefore eliminate most of these restrictions?
Surely a shop has access to fittings that can make this work, :confused:
Old Jun 27, 2002 | 01:15 PM
C54FUN's Avatar
C54FUN
St. Jude Donor '03-'05-'06-'08-'10
Default Re: Clutch lines... (C5Noir)
Levi, as I have the start of clutch problems (mushy pedal et al), was thinking along the lines as you suggest. Can't imagine why your suggestion could not be done by a competent shop. BTW, recall your being somewhat of a clutch changer, which are you running and what would you recommend. For the most part, mine is a daily driver with occasional trips to the track. For the most part, am stock for now, more than likely a cam/springs is in my near future. Appreciate the help and thanks.
Joe
