ac help please!
Old Jul 13, 2013 | 01:36 PM
adamd87's Avatar
adamd87
7th Gear
Default ac help please!
Hi guys i am workin on a 2000 vette with no ac. I have no power to the motor i was trying to check the pressure switch for continuity but could figure out which of the 3 prongs i should be reading. Can i just jimp the pressure switch if the compressor is unplugged to see if theat will give me power? Any help would be very apreciated
Old Jul 13, 2013 | 02:45 PM
martysauto's Avatar
martysauto
St. Jude Donor '14
No, don't jump anything! What type of ac do you have, auto climate control or manual? what motor? Blower motor? What are your exact symptoms?
Old Jul 13, 2013 | 03:11 PM
adamd87's Avatar
adamd87
7th Gear
Srry motor was a typo i meant compressor. The ac light comes on in the car then goes off the compressor clutch never goes. The system before this was recharged by a shop that managed to not notice the belt off the compressor so thats how it came to me. I put a belt on it then replaced the tensioner also. I dont know why the belt was off. I tried the ac and the clutch will not turn on checked for power at the clutch no power i was told the next step to diagnose the issue was to check the pressure switch
Old Jul 13, 2013 | 03:22 PM
martysauto's Avatar
martysauto
St. Jude Donor '14
get a set of ac gauges on it. The freon may have leaked out. You should have a static pressure close to ambient temp. If so you need to check and see if you have power and ground to the clutch. Can you turn the clutch by hand (engine off)?
Old Jul 13, 2013 | 03:31 PM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
There's absolutely no way that any shop could do a proper refrigerant charge with the belt being off of the compressor!
It sounds to me like you have a low refrigerant charge, which is why the compressor doesn't run. I would recommend a complete system evacuation with a vacuum pump, and see if holds a vacuum before going any further. Running it with a jumped out pressure switch can do damage to the compressor, since the refrigerant also carries oil through the compressor for lubrication to it's internal moving parts.
If it doesn't hold a vacuum, locate and repair the leak before recharging with the correct amount of R-134A refrigerant and PAG oil.
Old Jul 13, 2013 | 03:33 PM
adamd87's Avatar
adamd87
7th Gear
Thanks could u explain the terms ambient temp and static pressure to me
Old Jul 13, 2013 | 04:03 PM
adamd87's Avatar
adamd87
7th Gear
Is static pressure measured with the compressor not running? If so what readings should i get from The guage?
Old Jul 13, 2013 | 04:12 PM
Quicksilver Vert 01
Ambient= Temperature surrounding a person or object. (outdoor or garage temperature in this case)
Static Pressure= Pressure of the refrigerant in the system (compressor not running) at ambient temperature.
Old Jul 13, 2013 | 04:16 PM
Quicksilver Vert 01
The pressure is dependent on the ambient temperature. Higher ambient temperature will yield higher pressure.
Old Jul 13, 2013 | 04:27 PM
adamd87's Avatar
adamd87
7th Gear
thanks is there a chart
Old Jul 13, 2013 | 05:00 PM
adamd87's Avatar
adamd87
7th Gear
i have no reading from the guages. is this cause the clutch iks not engaged?
Old Jul 13, 2013 | 05:36 PM
adamd87's Avatar
adamd87
7th Gear
both guages show no change in the reading when hooked up is the system empty?
Old Jul 13, 2013 | 06:32 PM
TEXHAWK0's Avatar
TEXHAWK0
That's right. If both gauges read zero pressure with AC compressor off, then there is no freon pressure in the system.
Both gauges should read over 100 psi without the compressor running.
When the compressor is working, the low side pressure drops, and the high side pressure increases.
Old Jul 13, 2013 | 08:43 PM
Quicksilver Vert 01
On the charging gauges there will be a temperature scale. Match the pressure reading at the gauge needle with the temperature scale on the opposite side of the R-134a scale.
Old Jul 13, 2013 | 10:08 PM
dmarkshark's Avatar
dmarkshark
I believe if you look in the sticky sections you will find more info on what you are asking about.
Old Jul 13, 2013 | 10:29 PM
martysauto's Avatar
martysauto
St. Jude Donor '14
Actually you can. I just did it last weekend. the ac recycle/recharge machines have heaters to warm up the r134 tank. After I evacuated and vac tested mine, I set it to charge while i was working on another car. About ten minutes later, I went to start my engine and ac and it was already done charging. Not trying to bust *****. I agree with you 100% about his compressor not running because of low charge.
Old Jul 14, 2013 | 07:41 AM
Ronnie wilkins's Avatar
Ronnie wilkins
I just read it. It is under the "newbee" section and explains it very well.
To ac help please!
