Won't Start - Short Circuit
Old Jul 15, 2013 | 08:35 AM
SVTBAIT's Avatar
SVTBAIT
2015 C5 of Year Finalist
Default Won't Start - Short Circuit
I'm having a problem starting my car - I think I traced it to a 12v keyed-on wire that I spliced into not being connected to anything. I tried to start it and it didn't go.
I connected the 12v, and still didn't start. I'm now getting a clicking from the passanger side footwell. I disconnected the battery and reconnected it - when I reconnected it, one headlight went up.
Any help is very much appreciated
Old Jul 15, 2013 | 08:43 AM
runner140*'s Avatar
runner140*
I can't solve your problem but I think there is a starting point.
Check out your battery first, load test it at any or most auto parts stores for free. Make sure its in the 13.7 to 14.1 range. It needs to be measured with a dvm and not your DIC display.
Get back to us.
Old Jul 15, 2013 | 09:20 AM
SVTBAIT's Avatar
SVTBAIT
The engine does not crank. When I turn the key to start it, all that happens is a clicking.
I believe the security light blinks constantly. Even with the key out.
I'll pull the codes when I'm home.
Originally Posted by 8VETTE7
Insufficient info. Does the engine crank but NOT fire off? Or does the engine NOT crank?? What is happening with the security light when you turn the key on but do NOT try to crank the engine? On solid? OFF?? Blinks??
Pull ALL the codes and post them here including the H or C or HC that follow each 5 character code:
http://www.c5forum.com/ayc/dtcdic.php
OR
Old Jul 15, 2013 | 09:47 AM
SVTBAIT's Avatar
SVTBAIT
I feel as though this is related to when I tired to start the car with a 12v wire not grounded. I feel as though this caused and issue with a relay in passanger side footwell. I will pull codes when I get home today.
I really doubt it's the battery - it's been flawless and is virtually new. I really think it's something fuse or relay related.
Several possibilities based on the info you provided. First thing I would do is pull the battery and have it checked. Clicking could be caused by a bad or very low battery or loose or corroded battery connections.
The security light should blimk if the door is opened. When you put the key into the ignition and turn it toward the start position but DO NOT try to crank the engine the security light should go out.
Codes should help define the problem. If the pellet on the key is NOT being read correctly it should set a code and WILL prevent the engine from being cranked.
Old Jul 15, 2013 | 09:54 AM
65GGvert's Avatar
65GGvert
It may be just your terminology, but there is never an instance where a 12v wire should be grounded. That is called a short and will burn or blow something.
Old Jul 15, 2013 | 10:03 AM
SVTBAIT's Avatar
SVTBAIT
My mistake. I had a loose 12v wire that was not connected to anything. I'm immagining this was the issue. I'd imagine it was a short as you said.
You're right. I will.
I would STILL check the battery FIRST. JMHO.
To Won't Start - Short Circuit
