Bill Dearborn
Old Jul 18, 2013 | 05:09 PM
Wahoo12's Avatar
Wahoo12
Default Bill Dearborn
In 2009 you posted a thread showing the connections and wire colors for a 1999 harness at the EBCM.
Do you have one for a 02?
My understanding is
Pin A is hot all the time.
Pin B is hot in run mode.
Pin G is ground.
Not sure of the other pins.
Can I check voltage with the harness removed from the EBCM or not?
How do I check resistance in the wire from the PCM to the EBCM.
As you can see by my question, im treading water with electrial.
Trying to have all the information for what ever shop I use.
WJ
Old Jul 19, 2013 | 12:36 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Here is a 2001-2004 EBTCM power ground Schematic.
Yes you can read the power with the connector disconnected.
BC
Old Jul 19, 2013 | 09:58 AM
Wahoo12's Avatar
Wahoo12
Thanks BC this helps.
Wj
Old Jul 19, 2013 | 12:28 PM
Wahoo12's Avatar
Wahoo12
Bill,
With a test light;
Pin A is HOT
key in the run position
Pin B no POWER
Tested fuse#5 no Power. Tried different fuse no Power.
Any ideas?
WJ
Old Jul 19, 2013 | 01:26 PM
Wahoo12's Avatar
Wahoo12
Bill,
Key on fuses engine compartment
19,18,17,22,16,13 power
fuses pass
21,22,19 power
WJ
Old Jul 19, 2013 | 07:57 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Your ignition switch is bad.
- C5 ignition Switch repair - http://forums.corvetteforum.com/c5-t...ch-repair.html
Old Jul 19, 2013 | 10:42 PM
Wahoo12's Avatar
Wahoo12
Mr.Bill,
I thank you very much. I will follow your procedure for cleaning.
Have a great weekend.
WJ
To Bill Dearborn
