Fuel Smell
Old Jul 18, 2013 | 06:22 PM
Blackjetvette97's Avatar
Blackjetvette97
Default Fuel Smell
Hi all,
I've owned my '97 C5 since '98 and have had this issue on occasion recently. I live in Vegas and when it's super-hot and I drive the Vette, I get a fuel smell in my garage after parking it, like it's letting off vapors. Anyone else experience this or know what it stems from, if it is a problem?? I've had a friend's shop check the fuel sys for visible leaks n such, but nothing appears wrong. Thanks for any help.
Steve
Old Jul 18, 2013 | 07:59 PM
69's Avatar
69
Cruise-In VI Veteran
Hey Steve,
See if this is useful.
Kevin
97030: CAMPAIGN:FUEL TANK SENDING UNIT/PUMP SEAL LEAK - (Aug 19, 1997)
DEFECT INVOLVED
General Motors has decided that a defect which relates to motor vehicle safety exists in certain 1997 Chevrolet Corvette model vehicles. Some of these vehicles have a torn seal between the fuel tank and sending unit/pump. This may cause a fuel odor and/or leakage at the attachment location.
VEHICLES INVOLVED
Involved are all 1997 Chevrolet Corvette model vehicles built within the following VIN breakpoints:
PLANT YEAR MODEL PLANT CODE FROM THROUGH 1997 Corvette Bowling Green "5" V5100001 V5104113
What Will Be Done: to prevent the possibility of a fuel odor/leakage condition from a torn seal, your dealer will replace the left and right hand fuel tank assemblies (including fuel sending unit and pump).
Old Jul 18, 2013 | 08:52 PM
LoneStarFRC's Avatar
LoneStarFRC
Jack it up, remove L/R wheel, remove inner wheel-house, inspect filler neck hose clamp(s). Tighten as needed.
Btw, if you actually DO have a leaking gasket as per the GM TSB in 69's post, you do NOT have to replace the entire fuel pump/sending unit. Those gaskets are available separately for replacement if needed. Just be sure to buy the correct gasket for your year model. Note: right and left sides use the same gasket.
HTH
Old Jul 19, 2013 | 08:09 AM
69's Avatar
69
Hello, just a quick comment, can you please pull your car’s codes and post them to this thread?
I just want to see if there are codes for the EVAP system.
Kevin
Old Jul 19, 2013 | 09:25 AM
VinnyT's Avatar
VinnyT
Possible leaking fuel filter. I had to replace mine. No visable leaks but a strong fuel smell by the rear drivers side wheel.
Old Jul 19, 2013 | 01:50 PM
Blackjetvette97
Hi all,
Thanks for the replies and help. Kevin, here are the codes.
10-PCM..........P0461-H, P1431-H, P1571-H
28-TCS..........C1243-H
38-RTD..........No Comm
40-BCM.........No Codes
60-IPC..........B0521-H
80-Radio.......U1016-H
99-HVAC.......B0361-H & C
AO-LDCM.......B2282-H, U1064-H
A1-RDCM.......B2283-H, U1064-H
A6-SCM.........No Comm
BO-RFA.........U1255-H, U1096-H, U1064-H, C2105-H & C
Steve
Old Jul 19, 2013 | 06:53 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
Theres clams on the transfer tube above the fuel tanks. Check those if they are loose. Happened on mine
Old Jul 20, 2013 | 07:57 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
I had the same situation on my '01, and my problem was a leaking seal on the outbound side of the fuel filter also. It doesn't readily show up, because the fuel drips on to a hot exhaust pipe and evaporates off.
Yes, I know it sounds insane, but that's what happens....as long as you catch the problem in time!!
To Fuel Smell
