Passenger DRL out
Old Jul 18, 2013 | 06:25 PM
Blackjetvette97's Avatar
Blackjetvette97
Default Passenger DRL out
Hi all,
I've read a few posts on here about this issue and how it goes through the emergency flashers wiring, or something to that effect. My blinker works on that side and the other lights work too. So, I'm asking if it is the wiring issue, would my other lights works or would the whole side be out? I've changed the bulb and still it is out. Thanks for any help
Steve
Old Jul 18, 2013 | 08:49 PM
69's Avatar
69
Cruise-In VI Veteran
Originally Posted by Blackjetvette97
Hi all,
Steve
For a 1997 DRL System
Daytime Running Lamps (DRL) Headlamps Inoperative (DOMESTIC/EXPORT)
Daytime Running Lights Inoperative (Domestic/Export) Step
Action
Value(s)
Yes
No
1
Were you sent hear from the Headlights: Daytime Running Lamps (DRL) Diagnostic System Check?
Go to Step 2
Go to DRL Diagnostic System Check
2
Perform the BCM Diagnostic System Check.
Are any DTCs stored in memory?
Go to the applicable DTC table
Go to Step 3
3
Are both the LH and RH turn/park lamps inoperative during Daytime Running Lamps (DRL) operational mode?
Go to Step 32
Go to Step 4
4
Is just the RH turn/park lamp inoperative during DRL operational mode?
Go to Step 6
Go to Step 5
5
Is just the LH turn/park lamp inoperative during DRL operational mode?
Go to Step 19
6
Remove the DRL R Micro Relay #38 from the instrument panel electrical center.
Connect a DMM between the instrument panel electrical center terminal 87 which is used for the DRL R Micro Relay #38 and ground.
Measure the voltage at the instrument panel electrical center terminal 87.
Is the voltage within the specified values?
10.0-14.0V
Go to Step 8
Go to Step 7
7
Replace the instrument panel electrical center.
Is the repair complete?
8
Connect a fused jumper (10 A) between terminals 87 and 30 of the instrument panel electrical center which is used for the DRL R Micro Relay #38.
Does the RH turn/park illuminate?
Go to Step 10
Go to Step 9
9
Leave the fused jumper (10 A) in place.
Remove the RH turn/park lamp from its socket.
Connect a DMM between the RH turn/park lamp socket terminal A and ground.
Measure the voltage at terminal A.
10.0-14.0V
Go to Step 15
Go to Step 18
10
Reinstall the DRL R Micro Relay #38 back into the instrument panel electrical center.
Disconnect the BCM connector C2.
Connect a fused jumper (10 A) between the BCM connector C2 terminal D16 and ground.
Does the RH turn/park lamp illuminate?
Go to Step 11
Go to Step 12
11
Replace the BCM.
12
Connect a DMM between the instrument panel electrical center terminal 85 used for the DRL R Micro Relay #38 and the BCM connector C2 terminal D16.
Measure the continuity between the instrument panel electrical center terminal 85 and the BCM connector C2 terminal D16.
Is CKT 1915 continuous between these two terminals?
Go to Step 13
Go to Step 14
13
Replace the DRL R Micro Relay #38.
14
Repair the open in CKT 1915.
15
Connect the DMM between the RH turn/park lamp socket terminal G and ground.
Measure for continuity between the RH turn/park lamp socket terminal G and ground.
Is the CKT 150 continuous to ground?
Go to Step 17
Go to Step 16
16
Repair an open in CKT 150 between the RH turn/park lamp socket terminal G and G102.
17
Replace the RH turn/park lamp.
18
Repair an open in CKT 1315 between the instrument panel electrical center and the RH turn/park lamp.
19
Remove the DRL L Micro Relay #40 from the instrument panel electrical center.
Connect a DMM between the instrument panel electrical center terminal 87 which is used for the DRL R Micro Relay #40 and ground.
10.0-14.0V
Go to Step 21
Go to Step 20
20
21
Connect a fused jumper (10 A) between terminals 87 and 30 of the instrument panel electrical center which is used for the DRL L Micro Relay #40.
Go to Step 23
Go to Step 22
22
Remove the LH turn/park lamp from its socket.
Connect a DMM between the LH turn/park lamp socket terminal A and ground.
10.0-14.0V
Go to Step 28
Go to Step 31
23
Reinstall the DRL L Micro Relay #40 back into the instrument panel electrical center.
Disconnect the BCM connector C3.
Connect a fused jumper (10 A) between the BCM connector C3 terminal A7 and ground.
Does the LH turn/park lamp illuminate?
Go to Step 24
Go to Step 25
24
Replace the BCM.
25
Connect a DMM between the instrument panel electrical center terminal 85 used for the DRL L Micro Relay #40 and the BCM connector C2 terminal A7.
Measure the continuity between the instrument panel electrical center terminal 85 and the BCM connector C3 terminal A7.
Go to Step 26
Go to Step 27
26
Replace the DRL 7 Micro Relay #40.
27
Repair the open in CKT 1914.
28
Connect the DMM between the LH turn/park lamp socket terminal G and ground.
Measure for continuity between the LH turn/park lamp socket terminal G and ground.
Go to Step 30
Go to Step 29
29
Repair an open in CKT 150 between the LH turn/park lamp socket terminal G and G101.
30
Replace the LH turn/park lamp.
31
Repair an open in CKT 1314 between the instrument panel electrical center and the LH turn/park lamp.
32
Remove the APPROACH Minifuse® #2.
Connect a DMM between the instrument panel electrical center terminal A which is used for the APPROACH Minifuse® #2 and ground.
10.0-14.0V
Go to Step 33
Refer to Power Distribution
33
Connect a fused jumper (20 A) between the instrument panel electrical center terminal A and terminal B which is used for the APPROACH Minifuse® #2.
Does the 20 A fuse within the fused jumper immediately show an open circuit?
Go to Step 34
Go to Step 35
34
Repair a short to ground in CKT 2740.
35
Leave the fused jumper (20 A) in place between the instrument panel electrical center terminal A and terminal B which is used for the APPROACH Minifuse® #2.
Disconnect the instrument panel electrical center connector C1.
Connect a DMM between the instrument panel electrical center connector C1 terminal A9 and ground.
Measure the voltage at the instrument panel electrical center connector C1 terminal A9.
10.0-14.0V
Go to Step 36
Go to Step 37
36
37
Repair the open in CKT 2740.
