P0300 code
Old Jul 21, 2013 | 12:19 AM
2002redvette's Avatar
2002redvette
Default P0300 code
At the in-laws tonight for a little party. When it was time to leave, I started the car and it was running pretty rough. Drove a little further and it seemed to get worse. Then the check engine light came on and started flashing. I pulled into a parking lot and checked the codes. I got a P0300 code. Luckily I was just down the road from from my uncles shop, so I was going to just drop it off and have him look at it in the morning. I then started it and it ran just fine. I drove it home, about 25 miles, with no trouble. Is this something I should be worried about?
Old Jul 21, 2013 | 12:27 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
P-0300 is a RANDOM MISFIRE Normally, the problem is caused by defective spark-plug wires or a damaged / cracked plug insulator. If it was an out of the clear blue issue, it probably a plug wire issue.
One cylinder misfiring can feel like the engine is ready to self destruct!
Check to see if the wires are fully seated on the coil towers and on each plug. Was it raining or damp out??
If you find that you need wires, I recommend the GM Performance Red Wires. They are only 60ish dollars and fit and work flawlessly!
Contact www.gmpartshouse.com and talk to Gene or Patrick
Old Jul 21, 2013 | 12:29 AM
punz's Avatar
punz
St. Jude Donor '12-'13-'14-'15
That's the code that I had when I had a broken valve spring. Rough idle and sputter. Worth a look. I started with wires and plugs,all the same, pulled pass. valve cover and problem found.
Old Jul 21, 2013 | 12:31 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Here is a pic of the wires without the heat shield. You reuse your shields!
Old Jul 21, 2013 | 12:32 AM
BigGun's Avatar
BigGun
The P300 and flashing light indicates a misfire. Most common cause is loose or bad plug wires. It will probably happen again.
Old Jul 21, 2013 | 12:59 AM
2002redvette
As a matter of fact it was raining when I drove up there and while it was parked. It was also VERY humid when I left. I have had the car for just over a year. I don't really know much about the maintenance history. With just over 115000 miles, it is probably time anyway. Thanks for the help.
Old Jul 22, 2013 | 12:13 PM
JetMechZ16's Avatar
JetMechZ16
I recently had a similiar problem. I used an ohm meter and read the spark plug wires out. I had no idea what they should read but knew that if I had a big variation in readings from one wire to the next that would indicate a problem. All of my wires read between 27-30 ohms except one which read 6000 ohms. If I placed the tips of the meter into the core of the wire I got 27 ohms so it was a connection problem between the wire and the connector that went into the coil. Replaced the wires but read the new ones before installing to make sure they were good, all were 27-30 ohms again. Now I have 7 used spares just incase, threw the one bad one away.
Old Jul 28, 2013 | 02:53 PM
aerovette99's Avatar
aerovette99
Just had that code and the car ran horribly.
I removed all of the plugs and wires and checked for resistance (cleaned the plugs while I was in there anyway, and found that the silver housing around the plug was keeping two of my msd wires from seating properly.
I removed the 2 shields and the problem instantly went away.
As a matter of fact, the car had a mysterious miss at idle that went away also. Thought it was the throttle body so I removed that and cleaned it with throttle body cleaner, but that wasn't the problem, although the pedal response was incredible after I cleaned it!!!!!
To P0300 code
