My 2001 Vet coupe has 21,000 miles on it. Had it at the dealer for a strange engine noise (which they never did diagnose) and they told me the crankshaft pulley was "wobbling" slightly and would require replacing in the "near future" at $900. Is this a reasonable price?
LMAO!... no way is that reasonable!... a brand new pulley is about $70, $5 for a new bolt, and you can buy a puller and install tool for about $100... it isn't a hard job but is a little time consuming... the rack will need to be moved out of the way to get to the crank bolt... now would be a good time to consider a cam and pinning the crank as well
Thats about right for for dealer prices. A Vette shop would give you a much better deal. You can look at the pulley yourself and see if it is wobbling.
Depends upon what your dealership charges per hour for labor. Parts are a couple hundred bucks.
It's a common problem on the ls1.
Don't replace with a stock part. Aftermarket is the way to go. The wobble is caused by the rubber layer separating from the hub and the outer ring starting to move.
If you ever thought of doing cam on the car now is the time. You have pull a lot off the car to get to it. It's a big job if you are not mechanically inclined.
From: Ideals are peaceful...History is violent...St.Charles, MO.
C5 of Year Winner (appearance mods) 2019
St. Jude Donor '08-'09-'12 thru'22
$900 sounds like the stealership. As previously mentioned, a good 'Vette shop or a 'Vette guru in your area will save you hundreds.
When you do this do it right, a good SLP or Powerbond pulley with an ARP bolt. Also remember that you will need to purchase a new drive and accessory belts. Good luck
Age wise, It may very well need done. My 99's failed at 70k miles. But $900 is very steep. I paid $750 to have an ATI installed AND pinned to the crank. The pinning is around $100-150 itself in labor.
I even think $100-150 to pin the crank is still way too high unless that includes the price of the kit... a pin kit for stock balancers is about $75 and for your ati is prob around $120... in my opinion they shouldn't charge any extra labor (only for parts) to pin it once they are in there, it takes just a few mins to do... pinning is where you drill a small hole into the end of the crank/balancer... half of the hole is in the crank area and the other half in the balancer and you insert a small pin into that hole which prevents the balancer from spinning on the crank... it is mandatory if you ever supercharge the car so its a good idea to do it while you have the chance because it can save you a lot of time in the future... and a cam swap is also a good idea because removing the balaner is a great deal of what is involved with a cam swap
Just curious, and this may be off this topic, but how many higher mileage c5's out there that haven't had a failed balancer? And how many miles and still good? 77,000 on my original and no problems.
I have a 2001 vert with 80k and it started making a vibration that comes and goes like a sine wave at 70+MPH. It is not an extremely noticeable vibration, but it is there. The car has new tires and rims. I am going to take a look at this damper tonight to see if it is a possible source of my problem. If it looks ok, then I will have the wheels and tires rebalanced.
