draining coolant
Old Jul 28, 2013 | 02:25 AM
striper's Avatar
striper
Default draining coolant
2003 Z06. I'm having trouble getting my radiator drain plug open. Can't decide on correct tool and which way to turn. I've done this before a long time ago and seem to remember there was some unusual about doing this. Shop manual is very vague about this.
Old Jul 28, 2013 | 03:51 AM
ZeeOSix's Avatar
ZeeOSix
Here are notes I wrote last time I changed coolant.
Loosened the radiator draincock located on the lower right corner of the radiator. NOTE – the draincock is plastic, and only loosen 1/4 turn using a 1/4” square drive extension. Trying to loosen more than 1/4 turn can damage the draincock. I was able to open the draincock without jacking up the front end of the car.
Old Jul 28, 2013 | 05:49 AM
Turbooo2u's Avatar
Turbooo2u
I loosened the draincock 1/4 turn recently to change my coolant before I stripped the nylon plug. (only GM would come up with something this stupid). It wasn't close to coming out so I had to pop the stat to only get most of it out.
Old Jul 28, 2013 | 10:10 AM
Patches's Avatar
Patches
Done tthis several times - use a 1/4" square drive ratchet extension and turn it 1/4 turn CCW to loosen it. Last time I did it was last December when I was replacing the water pump and crank pulley. I discovered it is O-ring sealed and will actually come out all the way if you pull on it after loosening it - not that you need to to drain the radiator. I was playing with it and it popped out when I tugged on it.
Old Jul 28, 2013 | 11:35 AM
striper's Avatar
striper
So do you have to turn the plug to get it out or does it pull straight out? I assume you have to turn to a certain position to pull it out? Thanks for the forum, the shop manual says practically nothing about this, other than "loosen the drain plug to drain coolant."
Old Jul 28, 2013 | 01:11 PM
jcgunn's Avatar
jcgunn
The OEM plug is a POS plastic part with a metal pin. Use the 1/4 square drive, turn it 1/4 CCW and pull it out. If you turn it any more than that, you will shear the pin off (trust me). NAPA sells a replacement piece with "a butterfly wing" instead of the square drive, much easier to use.
Old Jul 28, 2013 | 03:31 PM
ZeeOSix's Avatar
ZeeOSix
There is no need to totally remove it. Just turn it 1/4 turn and the radiator will drain just fine without the draincock totally removed.
Old Jul 28, 2013 | 06:12 PM
1sickz51vette's Avatar
1sickz51vette
Where is the best or cheapest place to buy dexcool? I need to do this myself... Thanks for posting.
Old Jul 28, 2013 | 07:50 PM
striper's Avatar
striper
Walmart is considerably cheaper than Advance for Dexcool by Prestone. I needed to remove the plug to put in a new one that I didn't screw up the head on.
Old Jul 28, 2013 | 08:48 PM
Turbooo2u's Avatar
Turbooo2u
I swear I did this and nothing came out!
Old Jul 28, 2013 | 09:53 PM
racebum's Avatar
racebum
be a man, take a knife to the lower rad hose
Old Jul 29, 2013 | 09:34 AM
3boystoys's Avatar
3boystoys
All you have to do is turn it 1/4 turn and wiggle it out. Anything else WILL DESTROY THE PLUG.
Old Jul 29, 2013 | 09:49 AM
striper's Avatar
striper
FYI, for anyone wanting to change the original drain plug to the type with a wingnut end instead of the socket (I screwed up the socket on mine because it was stuck in there) when you get it out in the drain position you have to tug on it because there is a o-ring holding it in. The new one just pushes in until the o-ring is free and then you turn 1/4 turn clockwise by hand to close. I bought a new one at Advance for $4.99 with the wingnut end. Problem fixed. Now to go fill and bleed my system.
Old Jul 29, 2013 | 01:28 PM
ZeeOSix's Avatar
ZeeOSix
You happen to have the part number handy? Sounds like a decent way to go if the draincock needs replacing.
Old Jul 29, 2013 | 02:19 PM
DA1984VETTE's Avatar
DA1984VETTE
I don't mean to hi-jack the thread on this, but I may be replacing the t-stat in my 98. Do I need to drain the radiator completely or just a little like the good ole days? Thanks...and apologies to the op for this question.
Old Jul 30, 2013 | 03:11 AM
striper's Avatar
striper
Sorry, I couldn't find my receipt, but if you got to Advance it's just their GM replacement plug. The counterguy said they always have them in stock, retail is $4.99.
Old Jul 30, 2013 | 09:09 AM
imgn tht's Avatar
imgn tht
St. Jude Donor '13, '15
Is flushing the coolant really as simply as opening the drain **** to drain, close it back up and then fill up the radiator opening with new Dexcool?
It's been a long time since I had a car that had to have the coolant changed. Seem to remember my dad doing something with a hose to "flush" all the old out? It was a mess and seemed difficult...at least to a young teens eyes.
Dealership wants to charge me $150 to do the job. I'm an average DIYer, and have basic hand tools.
To draining coolant
Old Jul 30, 2013 | 03:05 PM
fixvet's Avatar
fixvet
I just picked one off the rack at Auto Zone....about $4 or so a couple of years ago.
Old Jul 30, 2013 | 04:46 PM
ZeeOSix's Avatar
ZeeOSix
If you just remove the radiator draincock and let the system drain, you only get about 3 quarts out of the system. Here's a trick I used last time I drain and filled the system to help get about 70% of the system to drain.
Remove the reservoir tank pressure cap and small rubber hose on the tank that comes from the top right of the radiator before draining the radiator. Loosened the radiator draincock located on the lower right corner of the radiator. After the radiator has drained, blow air into the reservoir tank filler cap hole with your mouth to help force coolant from the system. Cover the nipple on the reservoir tank that the small hose was connected to while blowing into the tank.
I got a total of ~8-1/2 quarts out of the system doing it this way. The Owner’s Manual says the total cooling system capacity is 12.6 quarts. So this drain & fill method got about ~70% of the system replaced. Good enough if you're replacing the coolant every 4~5 years with Dex-Cool.
Old Jul 31, 2013 | 03:47 PM
TEXHAWK0's Avatar
TEXHAWK0
If you look at the radiator housing around the plug closely, you can see the slot that the metal pin must be lined up with for the plug to pull straight out. You can turn it past the slot, and the plug will continue to come out, but the pin will retain the plug in the radiator housing.
The pin is in a spiral track, so that it slowly comes out as you turn it.
I have always been a little afraid that the 1/4" drive would round out the hole, so I usually end up carefully grabbing the outside edge of the plug with a small pair of channel-locks and wiggling it back until the coolant starts to come out...
