Reduced Engine Power
Old Jul 28, 2013 | 07:33 PM
c5-pewter's Avatar
c5-pewter
c5-pewter
St. Jude Donor '08
Default Reduced Engine Power
Reduced Engine Power (model year 2001 manual)
Car is parked, and in attempt to go somewhere (home) DIC suddenly reads, "Reduced Engine" Power, before I can Back out of the parking space. The engine won't rev above idle 800 RPM.
After a few hours I started the engine 3 times in succession, as a C-Forum Thread suggested. The car then ran fine, for about 100 yards, before the problem reoccurred.
However, after sitting for some indeterminate periods, the engine will rev again, perfectly.
Since then the electronics have been diagnosed by a reputable mechanic, with no conclusive findings to pinpoint the problem. I believe that a couple codes pointed into the wrong direction. As well, we have not been able to duplicate the condition after several days of keeping the engine running for extended periods of time.
The bottom line is that I'm afraid to take the car anywhere, for fear of getting stuck, or worse, causing an accident on a busy highway. Any suggestions are appreciated. Thanks, GRT
Old Jul 29, 2013 | 04:36 AM
Old Horsepower's Avatar
Old Horsepower
I think it might help if you posted the codes. First clear all of them. Then drive so new codes that are the problem will show up. I had this happen to me also. Reduced engine power and always at the worst time in traffic! Code said accelerator pedal position sensor. So I replaced it. That was it!
Old Jul 29, 2013 | 04:12 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I agree!! You MUST read your codes to determine what sensor/s are causing the issue. Read the codes BEFORE you turn the ignition off!!
Most of the time, Reduced Power happens when the Throttle By Wire system has an isue or fault. Coiuld be a Throttle Position Switch, accelerator pedal position sensor, TAC Module etc... So, reading the DTCS will help pinpoint the issue.
READING YOUR Engine Diagnostic Codes
The Diagnostic Display Mode is entered with the following procedure:
1) Turn on the ignition but don't start the engine. NOTE! You can read the DTCs with the engine running and or driving down the road but it can distract you. BE careful! Some DTCs clear themselves when you turn the ignition OFF!
2) Press the RESET button to turn off any warning messages. (i.e. door open, trunk open ect)
3) Press and hold OPTIONS
4) While holding OPTIONS, press FUEL four times within a 10-second period.
Initially, on-board diagnostics go into an Automatic Mode which shows diagnostic codes in a pre-set sequence: PCM - TCS - RTD - BCM - IPC - RADIO - HVAC - LDCM - RDCM - SCM - RFA. All codes will be displayed for each. ( i.e. PCM = 4 codes) If none are present in a given module, you will see No More Codes on the display.
There are two kinds of diagnostic codes, Current and History designated with a letter suffix, “C” or “H”. A current C code indicates a malfunction is present and active in the module displaying data. A history code indicates a problem existed sometime in the last 40 or 50 ignition cycles. When not accompanied by a current code of the same number, it's potential evidence of a previous problem, now resolved, that was not removed by clearing the codes.
More likely it's an indication of an intermittent malfunction.
Intermittent codes are the most challenging of the diagnostics. An intermittent code may have happened once, may have happened more than once but is inconsistent or may be happening on a regular basis but not at the time the codes are displayed. History codes can also be caused by a current malfunction in a system that is not operating at the time codes are displayed. An example is the rear window defogger which doesn't operate until the Body Control Module detects engine rpm. For history codes set by a module that does not operate with the key on and engine off, a special diagnostic tool called a Scan Tester is necessary to properly diagnose the malfunction.
Once the system has displayed all modules, it goes into the manual mode which allows selection of each module using combinations of Driver Information Center buttons. Manual mode can also be entered during the automatic sequence by pressing any button except English/Metric (E/M). Once the display shows Manual Diagnostics, select a module by pressing the OPTIONS button to go forward or the TRIP button to go back. Once a module is selected, a code is displayed, and if more than one are present; press GAGES to go forward or FUEL to go back.
To exit the diagnostic mode at any time, press E/M. If you want to erase codes in a given module, press and hold the RESET button To reset the codes once in manual mode, press and hold RESET until it displays NO CODES Press OPTIONS to go to the next module. Repeat the steps until you have reset the codes in all the computer modules.
NOTE!! Only reset the codes IF you want to - it is NOT necessary to do this. Clearing a code does not repair a problem. You are simply erasing the evidence of it in the module's memory. If you clear the code/s, and extinguish the Check Engine Light, your emissions status ready will NOT allow you to pass an emissions test until you have completed the required driving cycles.
Once you have the codes, the next question is: What to do with the information?
First, consult the factory service manual. Any serious C5 Do-It-Yourself owner should invest in the Corvette Service Manual of the appropriate model year. The Service Manual is really a requirement if you want to understand and work on your C5. You can GOOGLE the DTC and also find information on it.
Here is very good site that explains the DTCs:
http://www.corvette-web-central.com/C5DTCcode.html
http://www.obd-codes.com/trouble_cod...d-ii-codes.php
Make sure to include the H or C suffix!!
Bill
To Reduced Engine Power
