pitted sway bar causing noise?
Old Jul 31, 2013 | 01:02 PM
T_Vert's Avatar
T_Vert
Default pitted sway bar causing noise?
I've isolated it to the rear bar. I've replaced the bushings and it went away for a while then came back. I lubed it and the same thing happened. I knew it was pitted when I did all this but hoped I could just get away w/ new bushings. I've disassembled it one last time and used dry graphite powder in hopes that fixes it. Anyone ever have a bar pit before and did it cause loud operation?
I've attached a few pics also.
https://www.dropbox.com/s/4hk1lryz0n...2011.33.28.jpg
https://www.dropbox.com/s/b4e03ogjj5...2011.32.48.jpg
Thanks in advance.
Old Jul 31, 2013 | 01:36 PM
callie454's Avatar
callie454
Check the end links and associated hardware. Noise could be coming from there. Might look at upgrading to metal end links. Also, I've heard of away rusting from the inside out... Yours doesn't look that bad from those two pics, though. Hope this helps.
Old Jul 31, 2013 | 01:46 PM
T_Vert's Avatar
T_Vert
That is a z06 bar w/ metal end links. The end links move freely and quietly. I have no idea how a solid bar would rust from the inside out but the rest of the bar looks perfect. The car does not see rain or snow.
Dave
Old Jul 31, 2013 | 01:53 PM
callie454's Avatar
callie454
Not solid. Hollow. Seen it happen on a CF member's Z.
I'm on the mobile skin- can't see that you've got a Z. Since you posted in C5 tech vs Z06, I made an assumption. Sorry for the confusion.
So- You sure that its the sway? Try wrapping the bar in Teflon tape and mounting it back in. Wrap the tape only where it comes in contact with the bushings.
Could the noise originate from a shock? Upper control arm mount? Loose lugs? Reaching I'm sure, but I'd hate to miss something.
Old Jul 31, 2013 | 01:58 PM
T_Vert's Avatar
T_Vert
I have a non z06 w/ z06 bars sorry for the confusion. I wasn't aware they were hollow but I can see water getting into one and eating it from the inside out. I've removed the sway bar and noise went away so I'm 100% sure its the bushings. I've got Teflon tape up front and I may put it in the back if this graphite powder doesn't work. I just don't want to keep wasting my time w/ this if it is the pitting in the bar causing this.
Dave
Old Jul 31, 2013 | 02:02 PM
callie454's Avatar
callie454
I would give the Teflon tape fix a shot. Move on to more expensive options once the cheap fixes have run out.
Old Jul 31, 2013 | 02:08 PM
Socko's Avatar
Socko
Most of them look like that at this point. They dry out and then the bushing binds and rips the paint off the bar and it rusts.
You can do all sorta **** for a short term fix. Only way to fix it would be to get proper sized bushings for the bar once its recoated so it doesn't just rust again.
Honestly for the few thousand miles a year my car gets driven, i just regrease them a couple times a year.
Old Jul 31, 2013 | 02:14 PM
T_Vert's Avatar
T_Vert
Thanks. Like I said I put some graphite powder on it today and so far it is quiet. We'll see how long this lasts.
Dave
Old Jul 31, 2013 | 03:08 PM
T_Vert's Avatar
T_Vert
Or I just buy a new z06 sway bar. They aren't all that much.
Dave
Old Jul 31, 2013 | 03:41 PM
RonSSNova's Avatar
RonSSNova
Mine was rusted, then it broke in half.....I bet yours will too.
I'd buy a new bar.......
Ron
Old Jul 31, 2013 | 04:28 PM
T_Vert's Avatar
T_Vert
I may have to. I'd be shocked if a car that has never seen rain or water would have it's sway bar rust through.
Dave
To pitted sway bar causing noise?
