is this average oil pressure??
Old Jun 28, 2002 | 06:56 PM
Brad-Vette's Avatar
Brad-Vette
Default is this average oil pressure??
Hi guys,
on my 97, at idle i get 18 - 20 psi and over 30mph i get around 40 psi.
whats the average for a 97 with 35k miles?
thanks,
Brad
Old Jun 29, 2002 | 01:07 AM
Duck916's Avatar
Duck916
Default Re: is this average oil pressure?? (c5vette)
How many miles on the oil? If you've got over 10K, it's probably normal. I average around 27-28 when the oil is hot at idle (in gear--about 500 RPM) and 40-50 above 1000 rpm.
Either way, you're still well within GM specs.
Old Jun 29, 2002 | 03:03 AM
MelloYellow's Avatar
MelloYellow
Default Re: is this average oil pressure?? (Duck916)
Your oil pressure is getting too low. Find a way, ANY way to get a new pump put on before you spin a bearing.
Old Jun 29, 2002 | 03:30 AM
IrishMac's Avatar
IrishMac
Moderator Emeritus
Gone, but not Forgotten
Cruise-In 5, 6, 8 & 10 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09
My 98 manual states:
"Oil pressure should be between 20 to 80 psi. It could read as low as 6 psi and still be considered normal at long, extended idles."
I think you're okay. :yesnod:
Old Jun 29, 2002 | 04:02 AM
QuicksilverC5's Avatar
QuicksilverC5
Your oil pressure is JUST FINE. Don't sweat it. My 01 Coupe didn't get readings that high - 15 or so at idle and 30-35 with the original factory fill of 5-30 and went to about the same as your readings after the first change/fill with 10w-30 and a UPF filter. PLUS your readings are WELL within spec. 'Normal' oil pressure readings seems to be all over the map and depend on many variables BUT, as 98 BlackMagic said:
Again: don't sweat it. Believe what the FACTORY says; they built it (the engine) and THEY know what is normal.
Old Jun 29, 2002 | 11:11 AM
abraham's Avatar
abraham
Check your oil level. Thats not bad but a little low, mine does that when the oil is getting low.
Old Jun 30, 2002 | 03:30 AM
BAD 99's Avatar
BAD 99
Default Re: is this average oil pressure?? (abraham)
mines around that :smash:
ITS FINE ...........oil is gettig to the top ! that all that matters
To is this average oil pressure??
