water neck bolt leaking
Old Jul 31, 2013 | 09:32 PM
Bullet Proof's Avatar
Bullet Proof
Default water neck bolt leaking
Found the leak at least. I replaced the water pump a couple years ago. The lower water neck bolt is leaking coolant. I went to tighten it up and it won't tighten down. Do I need a new bolt? water pump ? water neck? Suggestions?
