Fog light issue
Old Jul 31, 2013 | 10:18 PM
david1st's Avatar
david1st
Default Fog light issue
Hey guys! My 02 Vert is having electrical issue... When I get into the car and shut my door and when I press the break peddle my fog light light up! Any idea what may be causing this? No codes Thanks!
Old Aug 1, 2013 | 12:02 AM
jcgunn's Avatar
jcgunn
Did you put in any LEDs?
Old Aug 1, 2013 | 09:31 AM
00Vette04GTO's Avatar
00Vette04GTO
Odd.....
Did you recently make any changes to the electrical system?
Or was your car like this when you bought it?
Or did this problem just "arise"?
Old Aug 1, 2013 | 08:03 PM
david1st's Avatar
david1st
I do have LEDs. And a hyper flash harness.
Old Aug 2, 2013 | 08:11 PM
david1st's Avatar
david1st
When the car is running and all lighs are off.. I press the break peddle .. Then door pad, stereo and dash display light up along with my fog lights come on. And my break light come on as they should! Any ideas!??
Old Aug 3, 2013 | 07:13 PM
jcgunn's Avatar
jcgunn
I had the same problem when I put LEDs in the tail lights. Fix was to go back to normal bulbs. Fronts are still LED switchbacks (works fine)
To Fog light issue
