Turn signals sporatic
Sometimes after I start the car and get on the road I realize the turn signals don't work - sometimews the hazards don't either, but mostly it is the turn signals. If I pull over and shut the car off and re-start (takes 1 or 2 tries) everything works fine.
This doesn't happen all the time, just every so often.
Any ideas?
Check into the bypass option, believe its easier than pulling the consol to get tot he switch...
http://www.kd5fx.com/HSwitch/HSwitch.htm
http://forums.corvetteforum.com/c5-t...=minute+hazard
Go to Google, type in C5 turn signals intermittent, or C5 turn signals don't work, or C5 hazard switch intermittent. Add in the search "forum" and you'll get everything you ever wanted to know about your issue. Use Google to search the forum, it filters out all the extra garbage the forum search brings up.
DTC B2578 Right Front Turn Signal Monitor Circuit
DTC B2583 Left Front Turn Signal Monitor Circuit
