Power problem
Old Jun 28, 2002 | 10:39 PM
warpster's Avatar
warpster
Default Power problem
OK normally I drive pretty sanely...tonight I tried to do a burnout both by stepping on it from a stop and then by trying to apply the brakes some while giving it gas...from a dead stop - no rubber, applying braking the engine would quickly bog down at about 1100 rpm....what gives???? Is this normal for a stock 2002 except for the Z06 cover and a K&N filter? If the car is throwing internal codes is there a way to get to them without anything special? Any ideas?
Thanks guys :confused:
Old Jun 28, 2002 | 10:44 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Default Re: Power problem (warpster)
is your car an automatic?
vetterdstr :chevy
Old Jun 28, 2002 | 10:45 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
St. Jude Donor '03-'04
Default Re: Power problem (vetterdstr)
tc/ah off?
Old Jun 28, 2002 | 10:46 PM
captfun's Avatar
captfun
This is a really dumb question, but somebody's gonna ask it. Might as well be me.
Was the T/C turned on or off?
capt.
Old Jun 28, 2002 | 10:54 PM
warpster's Avatar
warpster
Yes I do have an automatic
I tried it with the T/C both on and off...no difference
I also just looked at the codes, only IPC B0521H and SCM B2860H
from what I found one was a tack reporting problem and the other a telescoping wheel position sensor error.
Old Jun 28, 2002 | 11:12 PM
warpster's Avatar
warpster
OK correction......I just took it out again and made sure the T/C was off and the A/C was off....I can get it to brake loose using the brakes and it didn't bog down, but how high should I get the revs to get a good take off? From a dead stop without braking it won't brake loose for nothing, is this normal ?
Old Jun 28, 2002 | 11:25 PM
captfun's Avatar
captfun
With a 2.73 rearend, I think that's pretty normal. A4/2.73s are not noted for off the line grunt.
capt.
To Power problem
